[postgis-tickets] [PostGIS] #5476: winnie's build script is broken
PostGIS trac at osgeo.org
Sun Aug 13 19:18:52 PDT 2023
  Reporter:  robe                   |      Owner:  robe
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by robe):
 Okay what broke it is #5469.  I thought postgis install was working, but
 that was because I had hand edited that script.  It's broken like the
 others.
 The issue is on windows,
 MKDIR_P = @MKDIR_P@
 ends up becoming
 MKDIR_P =
 and that seems to break everything
 I'm testing to confirm
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5476#comment:7>
