[postgis-tickets] [SCM] PostGIS branch stable-3.4 updated. 3.4.0rc2-5-g03dbb4758
git at osgeo.org
git at osgeo.org
Sun Aug 13 20:12:14 PDT 2023
the project "PostGIS".
The branch, stable-3.4 has been updated
via 03dbb4758bcb4df63c872f5d99f6f408726ce3f9 (commit)
via 225468c858018d04cb9f63cd621e78cb626a7a5c (commit)
via 6fe8245b941b1358128b305b330512ac934a4373 (commit)
from 3789186fb8645a0131dac6af53735287ebd5f133 (commit)
revisions in full, below.
commit 03dbb4758bcb4df63c872f5d99f6f408726ce3f9
Author: Regina Obe <lr at pcorp.us>
Date: Sun Aug 13 23:10:04 2023 -0400
MKDIR_P only override if it's not empty
Closes #5469 for PostGIS 3.4.0rc3
Closes #5476 for PostGIS 3.4.0rc3
diff --git a/extensions/address_standardizer/Makefile.in b/extensions/address_standardizer/Makefile.in
index 31fca2d2f..44fcece78 100644
--- a/extensions/address_standardizer/Makefile.in
+++ b/extensions/address_standardizer/Makefile.in
@@ -205,7 +205,9 @@ PG_CONFIG := @PG_CONFIG@
PGXS := @PGXS@
include $(PGXS)
PERL = @PERL@
-MKDIR_P = @MKDIR_P@
+ifdef @MKDIR_P@
+ MKDIR_P = @MKDIR_P@
+endif
srcdir = @srcdir@
top_srcdir = @top_srcdir@
diff --git a/extensions/postgis/Makefile.in b/extensions/postgis/Makefile.in
index 4723145c9..518292e7f 100644
--- a/extensions/postgis/Makefile.in
+++ b/extensions/postgis/Makefile.in
@@ -149,7 +149,9 @@ PG_CONFIG := @PG_CONFIG@
PGXS := @PGXS@
include $(PGXS)
PERL = @PERL@
+ifdef @MKDIR_P@
+endif
VPATH = @srcdir@
diff --git a/extensions/postgis_raster/Makefile.in b/extensions/postgis_raster/Makefile.in
index 2842aad38..e3404014b 100644
--- a/extensions/postgis_raster/Makefile.in
+++ b/extensions/postgis_raster/Makefile.in
@@ -131,7 +131,9 @@ PG_CONFIG := @PG_CONFIG@
PGXS := @PGXS@
include $(PGXS)
PERL = @PERL@
+ifdef @MKDIR_P@
+endif
VPATH = @srcdir@
diff --git a/extensions/postgis_sfcgal/Makefile.in b/extensions/postgis_sfcgal/Makefile.in
index 7fea079f5..d127ddda8 100644
--- a/extensions/postgis_sfcgal/Makefile.in
+++ b/extensions/postgis_sfcgal/Makefile.in
@@ -103,7 +103,9 @@ PG_CONFIG := @PG_CONFIG@
PGXS := @PGXS@
include $(PGXS)
PERL = @PERL@
+ifdef @MKDIR_P@
+endif
VPATH = @srcdir@
diff --git a/extensions/postgis_tiger_geocoder/Makefile.in b/extensions/postgis_tiger_geocoder/Makefile.in
index 3c18ee7b6..5e4baa633 100644
--- a/extensions/postgis_tiger_geocoder/Makefile.in
+++ b/extensions/postgis_tiger_geocoder/Makefile.in
@@ -214,7 +214,9 @@ PG_CONFIG := @PG_CONFIG@
PGXS := @PGXS@
include $(PGXS)
PERL=@PERL@
+ifdef @MKDIR_P@
+endif
VPATH = @srcdir@
diff --git a/extensions/postgis_topology/Makefile.in b/extensions/postgis_topology/Makefile.in
index 75ba45c85..553182d2d 100644
--- a/extensions/postgis_topology/Makefile.in
+++ b/extensions/postgis_topology/Makefile.in
@@ -108,7 +108,9 @@ PG_CONFIG := @PG_CONFIG@
PGXS := @PGXS@
include $(PGXS)
PERL=@PERL@
+ifdef @MKDIR_P@
+endif
VPATH = @srcdir@
commit 225468c858018d04cb9f63cd621e78cb626a7a5c
Date: Sun Aug 13 23:07:45 2023 -0400
Put in news the two new configure switches
- --disable-extension-upgrades-install
- --without-pgconfig
diff --git a/NEWS b/NEWS
index 270fb28c1..acfaa8e53 100644
--- a/NEWS
+++ b/NEWS
@@ -10,6 +10,11 @@ Many thanks to our translation teams, in particular:
Teramoto Ikuhiro (Japanese Team)
Vincent Bre (French Team)
+There are 2 new ./configure switches:
+ - --disable-extension-upgrades-install, will skip installing all the extension upgrade scripts except for the ANY--currentversion. If you use this, you can install select upgrades using the postgis commandline tool
+ - --without-pgconfig, will build just the commandline tools
+ raster2pgsql and shp2pgsql even if PostgreSQL is not installed
* New Features *
- #5055, complete manual internationalization (Sandro Santilli)
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 897382c26..9f804e5d3 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -4,7 +4,7 @@
<subtitle>Release Notes</subtitle>
<sect1>
<title>PostGIS 3.4.0</title>
- <para>2023/08/13</para>
+ <para>2023/08/15</para>
<para>This version requires PostgreSQL 12 or higher, GEOS 3.6 or higher, and Proj 6.1+.
To take advantage of all features, GEOS 3.12+ is needed.
To take advantage of all SFCGAL featurs, SFCGAL 1.4.1+ is needed.</para>
@@ -13,6 +13,11 @@
<para>Teramoto Ikuhiro (Japanese Team)</para>
<para>Vincent Bre (French Team)</para>
+ <para>There are 2 new ./configure switches:</para>
+ <itemizedlist><listitem><para>--disable-extension-upgrades-install, will skip installing all the extension upgrade scripts except for the ANY--currentversion. If you use this, you can install select upgrades using the postgis commandline tool</para></listitem>
+ <listitem><para>--without-pgconfig, will build just the commandline tools raster2pgsql and shp2pgsql even if PostgreSQL is not installed</para></listitem>
+ </itemizedlist>
<simplesect>
<title>New features</title>
<para><ulink url="https://trac.osgeo.org/postgis/ticket/5055">5055</ulink>, complete manual internationalization (Sandro Santilli)</para>
commit 6fe8245b941b1358128b305b330512ac934a4373
Date: Sun Aug 13 22:33:19 2023 -0400
Winnie build changes:
- Standardize on 0 or 1 for INCLUDE_MINOR_LIB
- Set tagged builds to always be INCLUDE_MINOR_LIB=0
Others will default to INCLUDE_MINOR_LIB=1 or can be overwritten
diff --git a/ci/winnie/build_postgis.sh b/ci/winnie/build_postgis.sh
index 82e6e1fbb..24efa2044 100644
--- a/ci/winnie/build_postgis.sh
+++ b/ci/winnie/build_postgis.sh
@@ -1,7 +1,6 @@
#!/usr/bin/env bash
. $(dirname $0)/winnie_common.sh
-export INCLUDE_MINOR_LIB=1
if [ -n "$SOURCE_FOLDER" ]; then
export POSTGIS_SRC=${PROJECTS}/postgis/$SOURCE_FOLDER
@@ -12,7 +11,7 @@ else
else
#tagged version -- official release
export POSTGIS_SRC=${PROJECTS}/postgis/tags/${POSTGIS_VER}.${POSTGIS_MICRO_VERSION}
- INCLUDE_MINOR_LIB=false
+ INCLUDE_MINOR_LIB=0
fi;
fi;
diff --git a/ci/winnie/winnie_common.sh b/ci/winnie/winnie_common.sh
index c01b9a1d5..fe6b52fef 100644
--- a/ci/winnie/winnie_common.sh
+++ b/ci/winnie/winnie_common.sh
@@ -126,7 +126,7 @@ export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
#add lz4
export PATH="${LZ4_PATH}/bin:${LZ4_PATH}/lib:${PATH}"
-echo $PATH
+echo $PATH
export PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${LZ4_PATH}/lib/pkgconfig"
@@ -138,6 +138,6 @@ export PATH="${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin
echo "PATH AFTER: $PATH"
-if [[ "${INCLUDE_MINOR_LIB}" == '' ]] ; then
- export INCLUDE_MINOR_LIB=true
+if [[ "${INCLUDE_MINOR_LIB}" == "" ]] ; then
+ export INCLUDE_MINOR_LIB=1
fi;
Summary of changes:
NEWS | 5 +++++
ci/winnie/build_postgis.sh | 3 +--
ci/winnie/winnie_common.sh | 6 +++---
doc/release_notes.xml | 7 ++++++-
extensions/address_standardizer/Makefile.in | 4 +++-
extensions/postgis/Makefile.in | 4 +++-
extensions/postgis_raster/Makefile.in | 4 +++-
extensions/postgis_sfcgal/Makefile.in | 4 +++-
extensions/postgis_tiger_geocoder/Makefile.in | 4 +++-
extensions/postgis_topology/Makefile.in | 4 +++-
10 files changed, 33 insertions(+), 12 deletions(-)
hooks/post-receive
