[postgis-tickets] [PostGIS] #5469: make install fails on extensions
PostGIS trac at osgeo.org
Sun Aug 13 20:12:17 PDT 2023
  Reporter:  tbussmann              |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Changes (by Regina Obe <lr@…>):
 * status:  reopened => closed
 * resolution:   => fixed
Comment:
 In [changeset:"03dbb4758bcb4df63c872f5d99f6f408726ce3f9/git"
 03dbb475/git]:
 {{{#!CommitTicketReference repository="git"
 revision="03dbb4758bcb4df63c872f5d99f6f408726ce3f9"
 MKDIR_P only override if it's not empty
 Closes #5469 for PostGIS 3.4.0rc3
 Closes #5476 for PostGIS 3.4.0rc3
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5469#comment:6>
