[postgis-tickets] [PostGIS] #5477: distclean target fails (No rule to make target 'local-clean'.)
PostGIS trac at osgeo.org
Mon Aug 14 00:44:31 PDT 2023
  Reporter:  Bas Couwenberg         |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by Bas Couwenberg):
 The attached patch resolves the issue, it also removes an additional
 generated file that wasn't removed by the html-clean target.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5477#comment:1>
