[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-29-gdb710b834
Mon Aug 14 08:24:03 PDT 2023
the project "PostGIS".
       via  db710b834e3b85187895ce0f70b5ee0b63c1a7dc (commit)
       via  3ed65b69cbe89de0b9a59cb04215c90bd01471df (commit)
       via  5235846efe61998247e74a08002bc45002641eb3 (commit)
       via  876963598ab3618a26edcfe183dd89c5df21735f (commit)
      from  f4348feb455a61fb47b577df9c7868971cd70e45 (commit)
revisions in full, below.
commit db710b834e3b85187895ce0f70b5ee0b63c1a7dc
Merge: 3ed65b69c 876963598
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Aug 14 08:21:24 2023 -0700
    Merge branch 'master-warnings'
commit 3ed65b69cbe89de0b9a59cb04215c90bd01471df
Merge: f4348feb4 5235846ef
Date:   Mon Aug 14 08:21:08 2023 -0700
    Merge branch 'master-5175'
commit 5235846efe61998247e74a08002bc45002641eb3
Date:   Fri Aug 11 09:30:28 2023 -0700
    Add an explicit <> operator, closes #5175
diff --git a/postgis/lwgeom_btree.c b/postgis/lwgeom_btree.c
index bf3dd4922..df3fee1f6 100644
--- a/postgis/lwgeom_btree.c
+++ b/postgis/lwgeom_btree.c
@@ -43,6 +43,7 @@
 Datum lwgeom_lt(PG_FUNCTION_ARGS);
 Datum lwgeom_le(PG_FUNCTION_ARGS);
 Datum lwgeom_eq(PG_FUNCTION_ARGS);
+Datum lwgeom_neq(PG_FUNCTION_ARGS);
 Datum lwgeom_ge(PG_FUNCTION_ARGS);
 Datum lwgeom_gt(PG_FUNCTION_ARGS);
 Datum lwgeom_cmp(PG_FUNCTION_ARGS);
@@ -55,10 +56,7 @@ Datum lwgeom_lt(PG_FUNCTION_ARGS)
 	int cmp = gserialized_cmp(g1, g2);
 	PG_FREE_IF_COPY(g1, 0);
 	PG_FREE_IF_COPY(g2, 1);
-	if (cmp < 0)
-		PG_RETURN_BOOL(true);
-	else
-		PG_RETURN_BOOL(false);
+	PG_RETURN_BOOL(cmp < 0);
 PG_FUNCTION_INFO_V1(lwgeom_le);
@@ -69,10 +67,7 @@ Datum lwgeom_le(PG_FUNCTION_ARGS)
-	if (cmp <= 0)
-	else
+	PG_RETURN_BOOL(cmp <= 0);
 PG_FUNCTION_INFO_V1(lwgeom_eq);
@@ -83,10 +78,18 @@ Datum lwgeom_eq(PG_FUNCTION_ARGS)
-	if (cmp == 0)
-	else
+	PG_RETURN_BOOL(cmp == 0);
+PG_FUNCTION_INFO_V1(lwgeom_neq);
+	GSERIALIZED *g1 = PG_GETARG_GSERIALIZED_P(0);
+	GSERIALIZED *g2 = PG_GETARG_GSERIALIZED_P(1);
+	int cmp = gserialized_cmp(g1, g2);
+	PG_FREE_IF_COPY(g1, 0);
+	PG_FREE_IF_COPY(g2, 1);
+	PG_RETURN_BOOL(cmp != 0);
 PG_FUNCTION_INFO_V1(lwgeom_ge);
@@ -97,10 +100,7 @@ Datum lwgeom_ge(PG_FUNCTION_ARGS)
-	if (cmp >= 0)
-	else
+	PG_RETURN_BOOL(cmp >= 0);
 PG_FUNCTION_INFO_V1(lwgeom_gt);
@@ -111,10 +111,7 @@ Datum lwgeom_gt(PG_FUNCTION_ARGS)
-	if (cmp > 0)
-	else
+	PG_RETURN_BOOL(cmp > 0);
 PG_FUNCTION_INFO_V1(lwgeom_cmp);
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index c79ed40cb..af3ad2bab 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -398,6 +398,12 @@ CREATE OR REPLACE FUNCTION geometry_eq(geom1 geometry, geom2 geometry)
 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
 	_COST_DEFAULT;
+CREATE OR REPLACE FUNCTION geometry_neq(geom1 geometry, geom2 geometry)
+	RETURNS bool
+	AS 'MODULE_PATHNAME', 'lwgeom_neq'
+	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
+	_COST_DEFAULT;
 CREATE OR REPLACE FUNCTION geometry_cmp(geom1 geometry, geom2 geometry)
 	RETURNS integer
 	AS 'MODULE_PATHNAME', 'lwgeom_cmp'
@@ -431,7 +437,14 @@ CREATE OPERATOR <= (
 -- Availability: 0.9.0
 CREATE OPERATOR = (
 	LEFTARG = geometry, RIGHTARG = geometry, PROCEDURE = geometry_eq,
-	COMMUTATOR = '=', -- we might implement a faster negator here
+	COMMUTATOR = '=', NEGATOR = '<>',
+	RESTRICT = contsel, JOIN = contjoinsel, HASHES, MERGES
+-- Availability: 3.5.0
+CREATE OPERATOR <> (
+	LEFTARG = geometry, RIGHTARG = geometry, PROCEDURE = geometry_neq,
+	COMMUTATOR = '<>', NEGATOR = '=',
commit 876963598ab3618a26edcfe183dd89c5df21735f
Date:   Tue Aug 8 11:30:03 2023 -0700
    Quiet persistent warnings on MacOS, where the postgres-detected int64 is "long" while the system provided int64_t is "long long" and the printf specifier thus mis-matches, even though the actual internal size of "long" and "long long" is identical.
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index 01747aad8..f8b424afb 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -1407,7 +1407,7 @@ cb_getEdgeWithinDistance2D(const LWT_BE_TOPOLOGY *topo,
   LWT_ISO_EDGE *edges;
   int spi_result;
-  int64_t elems_requested = limit;
+  int64 elems_requested = limit;
   char *hexewkb;
   MemoryContext oldcontext = CurrentMemoryContext;
   StringInfoData sqldata;
@@ -1510,7 +1510,7 @@ cb_getNodeWithinDistance2D(const LWT_BE_TOPOLOGY *topo,
   char *hexewkb;
   StringInfo sql = &sqldata;
   uint64_t i;
   initStringInfo(sql);
@@ -1645,8 +1645,8 @@ cb_insertNodes(const LWT_BE_TOPOLOGY *topo, LWT_ISO_NODE *nodes, uint64_t numele
 	  cberror(topo->be_data,
 		  "processed " UINT64_FORMAT " rows, expected " UINT64_FORMAT,
-		  (uint64_t)SPI_processed,
-		  numelems);
+		  (uint64)SPI_processed,
+		  (uint64)numelems);
 	  return 0;
@@ -1705,8 +1705,8 @@ cb_insertEdges(const LWT_BE_TOPOLOGY *topo, LWT_ISO_EDGE *edges, uint64_t numele
-		  numelems);
 	  return -1;
@@ -1766,8 +1766,8 @@ cb_insertFaces(const LWT_BE_TOPOLOGY *topo, LWT_ISO_FACE *faces, uint64_t numele
-		  numelems);
 	  return -1;
@@ -2154,7 +2154,7 @@ cb_getNextEdgeId( const LWT_BE_TOPOLOGY* topo )
   if ( SPI_processed != 1 )
-	  cberror(topo->be_data, "processed " UINT64_FORMAT " rows, expected 1", (uint64_t)SPI_processed);
+	  cberror(topo->be_data, "processed " UINT64_FORMAT " rows, expected 1", (uint64)SPI_processed);
 	  return -1;
Summary of changes:
 postgis/lwgeom_btree.c      | 37 +++++++++++++++++--------------------
 postgis/postgis.sql.in      | 15 ++++++++++++++-
 topology/postgis_topology.c | 18 +++++++++---------
 3 files changed, 40 insertions(+), 30 deletions(-)
hooks/post-receive
