[postgis-tickets] [PostGIS] #5477: distclean target fails (No rule to make target 'local-clean'.)
PostGIS trac at osgeo.org
Mon Aug 14 10:58:08 PDT 2023
  Reporter:  Bas Couwenberg         |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.1
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by Regina Obe <lr@…>):
 In [changeset:"704301c0e0f3925571071ab001dffb0ab136e506/git" 704301c/git]:
 {{{#!CommitTicketReference repository="git"
 revision="704301c0e0f3925571071ab001dffb0ab136e506"
 distclean localize patch from Bas Couwenberg
 References #5477 for PostGIS 3.5.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5477#comment:4>
