[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-32-g7905ec144
Fri Aug 18 13:39:43 PDT 2023
the project "PostGIS".
       via  7905ec144ecee9896238a58c0883bd3e4c7a2854 (commit)
      from  6f6839a334a188edfc5a437ecc689621ee6c440d (commit)
revisions in full, below.
commit 7905ec144ecee9896238a58c0883bd3e4c7a2854
Author: Loïc Bartoletti <loic.bartoletti at oslandia.com>
Date:   Mon Apr 17 16:37:56 2023 +0200
    [macOS][CI] Add CI for macOS thanks to Cirrus-CI
    from Loic Bartoletti
    Closes https://github.com/postgis/postgis/pull/729
    for PostGIS 3.5.0
diff --git a/.cirrus.yml b/.cirrus.yml
index 26b3c8ab9..8d5fe6f85 100644
--- a/.cirrus.yml
+++ b/.cirrus.yml
@@ -38,3 +38,23 @@ task:
     - name: 13.2-RELEASE
       freebsd_instance:
         image_family: freebsd-13-2
+task:
+  name: macOS
+  alias: test-macos
+  test_script:
+    - brew update
+    - brew install autoconf automake libtool gpp pkg-config gdal geos json-c pcre2 postgresql at 14 proj protobuf-c sfcgal cunit
+    - ./autogen.sh
+    - ./configure --without-gui --without-interrupt-tests --without-topology --without-raster  --with-sfcgal --with-address-standardizer --with-protobuf --with-pgconfig=/opt/homebrew/opt/postgresql at 14/bin/pg_config
+    - brew services start postgresql at 14
+    - postgres -V
+    - make -j8 || { brew services stop postgresql at 14; exit 1;}
+    - make -j8 check || { brew services stop postgresql at 14; exit 1;}
+    - brew services stop postgresql at 14
+  matrix:
+    macos_instance:
+      image: ghcr.io/cirruslabs/macos-ventura-base:latest
+    macos_instance:
+      image: ghcr.io/cirruslabs/macos-monterey-base:latest
Summary of changes:
 .cirrus.yml | 20 ++++++++++++++++++++
 1 file changed, 20 insertions(+)
hooks/post-receive
