[postgis-tickets] [PostGIS] #5480: Old geos on docker latest image 3.4
PostGIS trac at osgeo.org
Mon Aug 21 14:34:51 PDT 2023
 Reporter:  latot                  |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 3.4.1
Component:  build/upgrade/install  |    Version:  3.4.x
 Keywords:                         |
 Hi!, I was testing the new release of 3.4 on docker, using the
 postgis/postgis:latest (I already pulled the new image).
 And then I found this:
 ST_LineMerge(
         ST_Collect(
                 vpv.half2,
                 next_geom.half1
         true
 ) geom
 ERROR: Directed line merging requires a build against GEOS-3.11 or higher,
 this version of PostGIS was built against version 3.9.0
 Now idea why, the latest image is compiled with a old version of geos.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5480>
