[postgis-tickets] [PostGIS] #5479: PostGIS_Full_Version: CRS EPSG:2163 is deprecated
PostGIS trac at osgeo.org
Mon Aug 21 15:29:05 PDT 2023
  Reporter:  tobwen   |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.4.1
 Component:  postgis  |    Version:  3.4.x
Resolution:           |   Keywords:
Comment (by robe):
 Does below trigger same version
 SELECT postgis_proj_version();
 And your above says you are running PROJ v6.2.1.  According to your hash
 you should be running PROJ v9.2.1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5479#comment:6>
