[postgis-tickets] [PostGIS] #5481: postgis_full_version() crashes backend due to invalid free from PROJ 6.3.1
PostGIS trac at osgeo.org
Tue Aug 22 03:31:33 PDT 2023
  Reporter:  strk     |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  high     |  Milestone:  PostGIS 3.4.1
 Component:  postgis  |    Version:  3.4.x
Resolution:  invalid  |   Keywords:
Changes (by strk):
 * status:  new => closed
 * resolution:   => invalid
Comment:
 The problem is that newer proj.db files dropped some columns, so older
 gdal using newer proj data are going to give this problem. Dropping the
 old gdal would be a fix, but this is obviously a packaging issue so cannot
 be fixed here.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5481#comment:3>
