[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-46-g86e0710d3
Wed Aug 23 09:36:39 PDT 2023
the project "PostGIS".
       via  86e0710d33e0693332d8acd5f8f3e29fccf2ff49 (commit)
      from  b1f7e19938afbedafa642bf3803b72fdb0af0ebd (commit)
revisions in full, below.
commit 86e0710d33e0693332d8acd5f8f3e29fccf2ff49
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Aug 23 18:34:28 2023 +0200
    Add script to check all available translations are enabled
    And hook it to make check
diff --git a/GNUmakefile.in b/GNUmakefile.in
index 7e8b1a698..e6ba14332 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -65,7 +65,7 @@ clean-local:
 # TODO: drop 'test' target..
 test: check
-check: check-no-trailing-blanks check-unit docs-check check-news check-tests-enabled
+check: check-no-trailing-blanks check-unit docs-check check-news check-tests-enabled check-lang-enabled
 ifeq (@LIBLWGEOM_ONLY@,no)
 check: check-regress
@@ -262,6 +262,10 @@ check-regress: staged-install check-regress-deps
 check-tests-enabled:
 	$(top_srcdir)/utils/check_tests_enabled.sh $(top_srcdir)
+check-lang-enabled:
+	$(top_srcdir)/utils/check_lang_enabled.sh $(top_srcdir)
 check-regress-deps:
 ifeq (@TOPOLOGY@,topology)
 	$(MAKE) -C topology/test $@
diff --git a/utils/check_lang_enabled.sh b/utils/check_lang_enabled.sh
new file mode 100755
index 000000000..96146c887
--- /dev/null
+++ b/utils/check_lang_enabled.sh
@@ -0,0 +1,60 @@
+#!/bin/sh
+usage() {
+  echo "Usage: $0 [<sourcedir>]"
+### COMMAND LINE PARSING
+RD= # Root source dir
+while [ $# -gt 0 ]; do
+  if [ "$1" = "--help" ]; then
+    usage
+    exit 0
+  elif [ -z "${RD}" ]; then
+    RD=$1
+  else
+    echo "ERROR: unrecognized extra argument $1" >&2
+    usage >&2
+    exit 1
+  fi
+  shift
+done
+if [ -z "${RD}" ]; then
+  RD=`dirname $0`/..
+fi
+test ${RD}/doc/po || {
+  echo "ERROR: Source dir ${RD} does not contain a doc/po directory" >&2
+  exit 1
+ENABLED_TRANSLATIONS=$(grep ^translations ${RD}/doc/Makefile.in | cut -d= -f2)
+fail=0
+CORRECTLY_ENABLED=
+# Available languages are those for which we have at least a .po file
+for LANG in $(
+  find ${RD}/doc/po/ -name '*.po' | xargs dirname | sort -u | xargs -n 1 basename
+do
+  # Check that the language dir has a Makefile.in
+  test -f ${RD}/doc/po/${LANG}/Makefile.in || {
+    echo "FAIL: ${RD}/doc/po/${LANG} is missing a Makefile.in"
+    fail=$((fail+1))
+    continue
+  echo "${ENABLED_TRANSLATIONS}" | grep -qw "${LANG}" || {
+    echo "FAIL: ${LANG} is not enabled in ${RD}/doc/Makefile.in (translations)"
+    fail=$((fail+1))
+    continue
+  echo "PASS: ${LANG} is correctly enabled"
+done
+exit $fail
Summary of changes:
 GNUmakefile.in              |  6 ++++-
 utils/check_lang_enabled.sh | 60 +++++++++++++++++++++++++++++++++++++++++++++
 2 files changed, 65 insertions(+), 1 deletion(-)
 create mode 100755 utils/check_lang_enabled.sh
hooks/post-receive
