[postgis-tickets] [PostGIS] #5484: ERROR: cannot drop function st_value(raster, geometry, boolean) because other objects depend on it
PostGIS trac at osgeo.org
Mon Aug 28 01:36:00 PDT 2023
#5484: ERROR:  cannot drop function st_value(raster,geometry,boolean) because
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.1
 Component:  build/upgrade/install  |    Version:  3.4.x
Resolution:                         |   Keywords:
Description changed by strk:
Old description:
> =# select postgis_extensions_upgrade();
> NOTICE:  Updating extension postgis from 3.1.1 to 3.4.0
> NOTICE:  Extension postgis_sfcgal is not available or not packagable for
> some reason
> NOTICE:  Updating extension postgis_raster from 3.1.1 to 3.4.0
> DETAIL:  view helmer_tmp.tracking_hr_with_rst_v depends on function
> HINT:  Use DROP ... CASCADE to drop the dependent objects too.
> CONTEXT:  SQL statement "ALTER EXTENSION postgis_raster UPDATE TO
> "3.4.0";"
> PL/pgSQL function postgis_extensions_upgrade() line 79 at EXECUTE
New description:
 some reason
 "3.4.0";"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5484#comment:1>
