[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-51-gac77210c6
Mon Aug 28 02:58:48 PDT 2023
the project "PostGIS".
       via  ac77210c64bd797b1ffcf8e0af9e1d4563419f6c (commit)
      from  73ab1e46e4cbe451e8436e88683a3d08bf60f547 (commit)
revisions in full, below.
commit ac77210c64bd797b1ffcf8e0af9e1d4563419f6c
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Aug 28 05:56:53 2023 -0400
    Update pos and pots
diff --git a/doc/po/de/reference_overlay.xml.po b/doc/po/de/reference_overlay.xml.po
index 49db3b0ef..2a4c7623c 100644
--- a/doc/po/de/reference_overlay.xml.po
+++ b/doc/po/de/reference_overlay.xml.po
@@ -5,7 +5,7 @@ msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2023-07-18 20:22+0000\n"
+"POT-Creation-Date: 2023-08-28 09:41+0000\n"
 "PO-Revision-Date: 2023-01-09 04:42+0000\n"
 "Last-Translator: Regina Obe <regina at arrival3d.com>\n"
 "Language-Team: German <https://weblate.osgeo.org/projects/postgis/"
@@ -576,7 +576,7 @@ msgstr ""
 #: reference_overlay.xml:454
 #, no-c-format
 msgid ""
-"Split a MultiLineString a Point, where the point lies exactly on both "
+"Split a MultiLineString by a Point, where the point lies exactly on both "
 "LineStrings elements."
 msgstr ""
diff --git a/doc/po/es/reference_overlay.xml.po b/doc/po/es/reference_overlay.xml.po
index b8a39a983..cb324d59e 100644
--- a/doc/po/es/reference_overlay.xml.po
+++ b/doc/po/es/reference_overlay.xml.po
@@ -6,7 +6,7 @@ msgid ""
 msgstr ""
 "PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
 "Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
 "Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
@@ -574,7 +574,7 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
diff --git a/doc/po/fr/reference_overlay.xml.po b/doc/po/fr/reference_overlay.xml.po
index e97e4b31d..1738fc019 100644
--- a/doc/po/fr/reference_overlay.xml.po
+++ b/doc/po/fr/reference_overlay.xml.po
 msgstr ""
 "PO-Revision-Date: 2023-07-03 15:08+0000\n"
 "Last-Translator: Vincent Bre <vincent.bre at oslandia.com>\n"
 "Language-Team: French <https://weblate.osgeo.org/projects/postgis/"
@@ -708,11 +708,9 @@ msgstr "Après la division"
 #, no-c-format
 msgid ""
 msgstr ""
-"Divise une MultiLineString en un point, où le point se trouve exactement sur "
-"les deux éléments de la LineString."
 #. Tag: para
 #: reference_overlay.xml:489
diff --git a/doc/po/it_IT/reference_overlay.xml.po b/doc/po/it_IT/reference_overlay.xml.po
index 011ad4123..fcfd17bca 100644
--- a/doc/po/it_IT/reference_overlay.xml.po
+++ b/doc/po/it_IT/reference_overlay.xml.po
 msgstr ""
 "PO-Revision-Date: 2022-02-18 09:52+0000\n"
 "Last-Translator: Sandro Santilli <strk at kbt.io>\n"
 "Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/"
 #, no-c-format
 msgid ""
 msgstr ""
diff --git a/doc/po/ja/reference_operator.xml.po b/doc/po/ja/reference_operator.xml.po
index 47c2854e8..3afccd323 100644
--- a/doc/po/ja/reference_operator.xml.po
+++ b/doc/po/ja/reference_operator.xml.po
@@ -1642,10 +1642,10 @@ msgid ""
 "for doing nearest neighbor searches using an N-dimensional index (requires "
 "PostgreSQL 9.5.0 or higher)."
 msgstr ""
-"<varname>|=|</varname>演算子は二つのトラジェクトリの3次元距離を返します ("
-"<xref linkend=\"ST_IsValidTrajectory\"/>を参照して下さい)。これは、<xref "
-"linkend=\"ST_DistanceCPA\"/>と同じですが、N次元インデックスを使った近傍探索 ("
-"PostgreSQL 9.5.0以上)で使われる演算子です。"
+"<varname>|=|</varname>演算子は二つのトラジェクトリの3次元距離を返します "
+"(<xref linkend=\"ST_IsValidTrajectory\"/>を参照して下さい)。これは、<xref "
+"linkend=\"ST_DistanceCPA\"/>と同じですが、N次元インデックスを使った近傍探索 "
+"(PostgreSQL 9.5.0以上)で使われる演算子です。"
 #. Tag: para
 #: reference_operator.xml:1718
diff --git a/doc/po/ja/reference_overlay.xml.po b/doc/po/ja/reference_overlay.xml.po
index f4ad33c44..d43cae498 100644
--- a/doc/po/ja/reference_overlay.xml.po
+++ b/doc/po/ja/reference_overlay.xml.po
 msgstr ""
 "PO-Revision-Date: 2023-07-14 10:08+0000\n"
 "Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
@@ -686,11 +686,9 @@ msgstr "分割後"
 #, no-c-format
 msgid ""
 msgstr ""
-"マルチラインストリングをポイントで分割しますが、ポイントは確実にラインストリ"
-"ングの要素の上に存在しています。"
 #. Tag: para
diff --git a/doc/po/ja/release_notes.xml.po b/doc/po/ja/release_notes.xml.po
index 42fc396fb..69afa9e91 100644
--- a/doc/po/ja/release_notes.xml.po
+++ b/doc/po/ja/release_notes.xml.po
@@ -51,9 +51,9 @@ msgid ""
 "To take advantage of all features, GEOS 3.12+ is needed. To take advantage "
 "of all SFCGAL featurs, SFCGAL 1.4.1+ is needed."
 msgstr ""
-"このバージョンにはPostgreSQL 12-16、GEOS 3.6以上、Proj 6.1以上が必要です。"
-"全ての機能を利用するにはGEOS 3.12以上が必要です。"
-"全てのSFCGAL機能を使用するにはSFCGAL 1.4.1以上が必要です。"
+"このバージョンにはPostgreSQL 12-16、GEOS 3.6以上、Proj 6.1以上が必要です。全"
+"ての機能を利用するにはGEOS 3.12以上が必要です。全てのSFCGAL機能を使用するには"
+"SFCGAL 1.4.1以上が必要です。"
 #. Tag: para
 #: release_notes.xml:11
diff --git a/doc/po/ko_KR/reference_bbox.xml.po b/doc/po/ko_KR/reference_bbox.xml.po
index e9c49b3ba..4623578e5 100644
--- a/doc/po/ko_KR/reference_bbox.xml.po
+++ b/doc/po/ko_KR/reference_bbox.xml.po
@@ -1,20 +1,3 @@
-# SOME DESCRIPTIVE TITLE.
-# FIRST AUTHOR <EMAIL at ADDRESS>, YEAR.
-#, fuzzy
-msgid ""
-msgstr ""
-"Project-Id-Version: PACKAGE VERSION\n"
-"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
-"Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
-"Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
-"Language: \n"
-"MIME-Version: 1.0\n"
-"Content-Type: text/plain; charset=UTF-8\n"
-"Content-Transfer-Encoding: 8bit\n"
 #. Tag: para
 #: reference_bbox.xml:5
 #, no-c-format
diff --git a/doc/po/ko_KR/reference_overlay.xml.po b/doc/po/ko_KR/reference_overlay.xml.po
--- a/doc/po/ko_KR/reference_overlay.xml.po
+++ b/doc/po/ko_KR/reference_overlay.xml.po
 msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
diff --git a/doc/po/pl/reference_overlay.xml.po b/doc/po/pl/reference_overlay.xml.po
--- a/doc/po/pl/reference_overlay.xml.po
+++ b/doc/po/pl/reference_overlay.xml.po
 msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
diff --git a/doc/po/pt_BR/reference_overlay.xml.po b/doc/po/pt_BR/reference_overlay.xml.po
index 2cd56936a..62902d600 100644
--- a/doc/po/pt_BR/reference_overlay.xml.po
+++ b/doc/po/pt_BR/reference_overlay.xml.po
 msgstr ""
@@ -578,7 +578,7 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
diff --git a/doc/po/ru/reference_overlay.xml.po b/doc/po/ru/reference_overlay.xml.po
index 98998aad5..d852ba796 100644
--- a/doc/po/ru/reference_overlay.xml.po
+++ b/doc/po/ru/reference_overlay.xml.po
 msgstr ""
 "PO-Revision-Date: 2021-11-08 06:12+0000\n"
 "Last-Translator: Automatically generated\n"
 "Language-Team: none\n"
@@ -575,7 +575,7 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
diff --git a/doc/po/templates/reference_overlay.xml.pot b/doc/po/templates/reference_overlay.xml.pot
index c10df2ad7..526f8d69e 100644
--- a/doc/po/templates/reference_overlay.xml.pot
+++ b/doc/po/templates/reference_overlay.xml.pot
 msgstr ""
@@ -573,7 +573,7 @@ msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
Summary of changes:
 doc/po/de/reference_overlay.xml.po         |  4 ++--
 doc/po/es/reference_overlay.xml.po         |  4 ++--
 doc/po/fr/reference_overlay.xml.po         |  6 ++----
 doc/po/it_IT/reference_overlay.xml.po      |  4 ++--
 doc/po/ja/reference_operator.xml.po        |  8 ++++----
 doc/po/ja/reference_overlay.xml.po         |  6 ++----
 doc/po/ja/release_notes.xml.po             |  6 +++---
 doc/po/ko_KR/reference_bbox.xml.po         | 17 -----------------
 doc/po/ko_KR/reference_overlay.xml.po      |  4 ++--
 doc/po/pl/reference_overlay.xml.po         |  4 ++--
 doc/po/pt_BR/reference_overlay.xml.po      |  4 ++--
 doc/po/ru/reference_overlay.xml.po         |  4 ++--
 doc/po/templates/reference_overlay.xml.pot |  4 ++--
 13 files changed, 27 insertions(+), 48 deletions(-)
hooks/post-receive
