[postgis-tickets] [PostGIS] #5484: ERROR: cannot drop function st_value(raster, geometry, boolean) because other objects depend on it
PostGIS trac at osgeo.org
Mon Aug 28 04:01:52 PDT 2023
#5484: ERROR:  cannot drop function st_value(raster,geometry,boolean) because
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.1.10
 Component:  build/upgrade/install  |    Version:  2.1.x
Resolution:                         |   Keywords:
Comment (by strk):
 Fixing this problem is tricky because the `Replaces` comment handling does
 not support specifying argument names, so while that comment is ok to
 handle adding parameters with default values it isn't good in its current
 form to change parameter names.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5484#comment:8>
