[postgis-tickets] [PostGIS] #5486: Upgrade from 3.2.1 fails due to deprecating two flavors of st_dwithin
PostGIS trac at osgeo.org
Mon Aug 28 08:49:36 PDT 2023
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.3.5
 Component:  build/upgrade/install  |    Version:  3.3.x
Resolution:                         |   Keywords:
Comment (by strk):
 I get the same failure going from 3.2.1 to 3.2.6dev
 The fix might be just including the OID of the deprecated function in the
 name, should work fine. I'm going to test this in a PR
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5486#comment:7>
