[postgis-tickets] [PostGIS] #5486: Upgrade from 3.2.1 fails due to deprecating two flavors of st_dwithin
PostGIS trac at osgeo.org
Mon Aug 28 09:15:13 PDT 2023
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.3.5
 Component:  build/upgrade/install  |    Version:  3.3.x
Resolution:                         |   Keywords:
Comment (by strk):
 The oldest version from which Dronie tests upgrades is 3.0.6 which
 explains why CI is green. In turn, the reason why Dronie only tests 3.0.6
 is, I believe, that earlier versions do not support PostgreSQL-13 which is
 the oldest Dronie is testing.
 We'd need a test for PostgresSQL-12 to get this bug visible in Dronie.
 Regina any reason for not re-introducing PostgreSQL-12 testing there ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5486#comment:10>
