[postgis-tickets] [PostGIS] #5487: Confusing error when upgrading from partially upgraded database
PostGIS trac at osgeo.org
Mon Aug 28 09:52:27 PDT 2023
 Reporter:  strk                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS Fund Me
Component:  build/upgrade/install  |    Version:  master
 Keywords:                         |
 This is a spin off of #5486
 When upgrading your PostGIS database while having a view holding back a
 deprecated function you end up having a partially upgraded database, which
 is reported with a WARNING during the upgrade and by
 postgis_full_version()
 When upgrading again you don't get a clear message about problems BUT you
 may get an error about being it impossible to rename a deprecated function
 (because the deprecated function name already exists).
 This ticket may serve to improve this situation.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5487>
