[postgis-tickets] [PostGIS] #5488: Upgrade from 3.1.1: ERROR: cannot drop function st_clip(raster, integer, geometry, double precision, boolean) because other objects depend on it
PostGIS trac at osgeo.org
Mon Aug 28 13:04:47 PDT 2023
st_clip(raster,integer,geometry,double precision,boolean) because other
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:
 Component:  build/upgrade/install  |    Version:
Resolution:                         |   Keywords:
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"e1b7db45486fea9cb3c0be8d58cbd2a785b631f4/git"
 e1b7db45/git]:
 {{{#!CommitTicketReference repository="git"
 revision="e1b7db45486fea9cb3c0be8d58cbd2a785b631f4"
 Fix upgrades in presence of views using ST_Clip
 Includes regress test
 References #5488 in master branch (3.5.0dev)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5488#comment:8>
