[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-64-g3ecd48c7f
Tue Aug 29 01:57:48 PDT 2023
the project "PostGIS".
       via  3ecd48c7fa8c97142e00fd4e5467ca22223a0f93 (commit)
      from  99ddb20a49b739c4f6d566d14359b3f8dfa5fd42 (commit)
revisions in full, below.
commit 3ecd48c7fa8c97142e00fd4e5467ca22223a0f93
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Aug 28 23:28:56 2023 +0200
    Fix upgrades in presence of views using st_slope(..raster..)
    Adds availability info to the function signatures
    References #5490 in master branch (3.5.0dev)
diff --git a/raster/rt_pg/rtpostgis.sql.in b/raster/rt_pg/rtpostgis.sql.in
index 5424398fb..e30389607 100644
--- a/raster/rt_pg/rtpostgis.sql.in
+++ b/raster/rt_pg/rtpostgis.sql.in
@@ -3465,11 +3465,15 @@ CREATE OR REPLACE FUNCTION _st_slope4ma(value double precision[][][], pos intege
 	END;
 	$$ LANGUAGE 'plpgsql' IMMUTABLE PARALLEL SAFE;
+-- Availability: 2.1.0
 CREATE OR REPLACE FUNCTION st_slope(
-	rast raster, nband integer,
+	rast raster,
+	nband integer,
 	customextent raster,
-	pixeltype text DEFAULT '32BF', units text DEFAULT 'DEGREES',
-	scale double precision DEFAULT 1.0,	interpolate_nodata boolean DEFAULT FALSE
+	pixeltype text DEFAULT '32BF',
+	units text DEFAULT 'DEGREES',
+	scale double precision DEFAULT 1.0,
+	interpolate_nodata boolean DEFAULT FALSE
 	RETURNS raster
 	AS $$
@@ -3525,10 +3529,16 @@ CREATE OR REPLACE FUNCTION st_slope(
 	END;
+-- Availability: 2.0.0
+-- Changed: 2.1.0 added units, scale and interpolate_nodata
+-- Replaces st_slope(raster, integer, text) deprecated in 2.1.0
-	rast raster, nband integer DEFAULT 1,
+	rast raster,
+	nband integer DEFAULT 1,
 	RETURNS raster
 	AS $$ SELECT @extschema at .ST_slope($1, $2, NULL::@extschema at .raster, $3, $4, $5, $6) $$
diff --git a/raster/rt_pg/rtpostgis_drop.sql.in b/raster/rt_pg/rtpostgis_drop.sql.in
index ef6a57ada..72c4e085d 100644
--- a/raster/rt_pg/rtpostgis_drop.sql.in
+++ b/raster/rt_pg/rtpostgis_drop.sql.in
@@ -63,6 +63,11 @@ DROP FUNCTION IF EXISTS ST_Intersects(geometry, raster, integer, boolean);
 -- Removed in 2.1.0, see ticket #5489
 DROP FUNCTION IF EXISTS _st_intersects(raster, geometry, integer);
+-- Removed in 2.1.0, see ticket #5490
+DROP FUNCTION IF EXISTS _st_slope4ma(float8[], text, text[]);
+-- Removed in 2.0.0 ? see ticket #5490
+DROP FUNCTION IF EXISTS st_slope(raster, integer, text, boolean);
 DROP FUNCTION IF EXISTS ST_Intersection(raster,raster, integer, integer);
 DROP FUNCTION IF EXISTS ST_Intersection(geometry,raster);
diff --git a/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in b/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
index fcde527e2..d08f34b59 100644
--- a/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
+++ b/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
@@ -511,9 +511,6 @@ DROP FUNCTION IF EXISTS _st_contains(geometry, raster, integer);
 DROP FUNCTION IF EXISTS st_addband(raster, raster[], integer);
 -- function signatures changed
-DROP FUNCTION IF EXISTS st_slope(raster, integer, text, text, double precision, boolean);
-DROP FUNCTION IF EXISTS st_slope(raster, integer, text, boolean);
-DROP FUNCTION IF EXISTS st_slope(raster, integer, text);
 DROP FUNCTION IF EXISTS st_aspect(raster, integer, text, text, boolean);
 DROP FUNCTION IF EXISTS st_aspect(raster, integer, text, boolean);
 DROP FUNCTION IF EXISTS st_aspect(raster, integer, text);
@@ -567,7 +564,6 @@ DROP FUNCTION IF EXISTS st_asbinary(raster);
 DROP FUNCTION IF EXISTS _st_aspect4ma(float8[], text, text[]);
 DROP FUNCTION IF EXISTS _st_hillshade4ma(float8[], text, text[]);
-DROP FUNCTION IF EXISTS _st_slope4ma(float8[], text, text[]);
 -- function signature changed
 DROP FUNCTION IF EXISTS st_gdaldrivers();
diff --git a/raster/test/regress/hooks/hook-after-upgrade-raster.sql b/raster/test/regress/hooks/hook-after-upgrade-raster.sql
index bb94684ae..950bf3631 100644
--- a/raster/test/regress/hooks/hook-after-upgrade-raster.sql
+++ b/raster/test/regress/hooks/hook-after-upgrade-raster.sql
@@ -5,5 +5,7 @@ DROP VIEW upgrade_test_raster_view_st_intersects;
 DROP TABLE upgrade_test_raster;
 DROP TABLE upgrade_test_raster_with_regular_blocking;
+DROP VIEW upgrade_test_raster_view_st_slope;
 -- Drop functions deprecated on upgrade
 DROP FUNCTION IF EXISTS st_value_deprecated_by_postgis_201(raster,geometry,boolean);
diff --git a/raster/test/regress/hooks/hook-before-upgrade-raster.sql b/raster/test/regress/hooks/hook-before-upgrade-raster.sql
index 305bd7d05..92d64879b 100644
--- a/raster/test/regress/hooks/hook-before-upgrade-raster.sql
+++ b/raster/test/regress/hooks/hook-before-upgrade-raster.sql
@@ -60,3 +60,9 @@ SELECT
 	st_intersects(NULL::geometry, NULL::raster, NULL::int) sig3,
 	st_intersects(NULL::raster, NULL::geometry, NULL::int) sig4,
 	st_intersects(NULL::raster, NULL::int, NULL::geometry)  sig5;
+-- See https://trac.osgeo.org/postgis/ticket/5490
+CREATE VIEW upgrade_test_raster_view_st_slope AS
+SELECT
+	st_slope(NULL::raster, NULL::int, NULL::raster) sig1,
+	st_slope(NULL::raster, NULL::int) sig2;
Summary of changes:
 raster/rt_pg/rtpostgis.sql.in                      | 22 ++++++++++++++++------
 raster/rt_pg/rtpostgis_drop.sql.in                 |  5 +++++
 raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in      |  4 ----
 .../regress/hooks/hook-after-upgrade-raster.sql    |  2 ++
 .../regress/hooks/hook-before-upgrade-raster.sql   |  6 ++++++
 5 files changed, 29 insertions(+), 10 deletions(-)
hooks/post-receive
