[postgis-tickets] [PostGIS] #5492: Presence of deprecated functions is not reported by `postgis` script
PostGIS trac at osgeo.org
Tue Aug 29 07:30:36 PDT 2023
 Reporter:  strk     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.4.1
Component:  postgis  |    Version:  3.4.x
 Keywords:           |
 The `postgis status` command does not report that deprecated functions are
 in use. Deprecated functions are those who are left behind due to views or
 other objects depending on functions whose signatures have been deprecated
 by a PostGIS upgrade. Such state is reported by `postgis_full_version()`
 like this:
 > POSTGIS="3.4.0 0874ea3" [EXTENSION] PGSQL="120"
 GEOS="3.10.1-CAPI-1.16.0" SFCGAL="1.3.7" PROJ="8.2.0 NETWORK_ENABLED=OFF
 URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/tmp/proj
 DATABASE_PATH=/usr/share/proj/proj.db" GDAL="GDAL 3.4.3, released
 2022/04/22" LIBXML="2.9.10" LIBJSON="0.13.1" LIBPROTOBUF="1.3.3"
 WAGYU="0.5.0 (Internal)" TOPOLOGY RASTER (deprecated functions exist,
 upgrade is not complete)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5492>
