[postgis-tickets] [PostGIS] #5494: st_dwithin(text, text, float8) is marked as deprecated and installed by the same postgis version
PostGIS trac at osgeo.org
Tue Aug 29 08:09:09 PDT 2023
#5494: st_dwithin(text,text,float8) is marked as deprecated and installed by the
  Reporter:  strk      |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  critical  |  Milestone:  PostGIS 3.1.10
 Component:  postgis   |    Version:  master
Resolution:            |   Keywords:  upgrade, deprecation, st_dwithin
Changes (by strk):
 * version:  3.4.x => master
 * milestone:  PostGIS 3.4.1 => PostGIS 3.1.10
Comment:
 The `ST_DWithin(text, text, float8)` signature is defined in
 postgis/geography.sql.in at least since postgis-1.5 and it doesn't look
 like having ever be deprecated, so those commits were plain wrong.
 Fix needs to be backported up to 3.1 branch
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5494#comment:2>
