[postgis-tickets] [PostGIS] #5035: st_dwithin(geography, geography, double precision) needs a REPLACE note and document change
PostGIS trac at osgeo.org
Tue Aug 29 08:32:40 PDT 2023
#5035: st_dwithin(geography,geography,double precision) needs a REPLACE note and
document change
  Reporter:  robe     |      Owner:  strk
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 3.1.5
 Component:  postgis  |    Version:  2.5.x -- EOL
Resolution:  fixed    |   Keywords:
Comment (by strk):
 For the record, the fix for this partially broken as a Replaces for
 text,text was added while the text,text signature is still around (defined
 in geography.sql) See #5494
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5035#comment:9>
