[postgis-tickets] [PostGIS] #5494: st_dwithin(text, text, float8) is marked as deprecated and installed by the same postgis version
PostGIS trac at osgeo.org
Tue Aug 29 08:38:49 PDT 2023
#5494: st_dwithin(text,text,float8) is marked as deprecated and installed by the
  Reporter:  strk      |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  critical  |  Milestone:  PostGIS 3.1.10
 Component:  postgis   |    Version:  master
Resolution:            |   Keywords:  upgrade, deprecation, st_dwithin
Comment (by strk):
 I've verified 1.3.0 already had the function taking geometry, so the 1.3.4
 line is wrong. I can say 1.2.1 did not have it and 1.2.2 did not exist so
 the availabilty line should say 1.3.0, where it had no parameter names.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5494#comment:4>
