[postgis-tickets] [PostGIS] #5493: No tools are given to resolve presence of deprecated functions
PostGIS trac at osgeo.org
Tue Aug 29 11:06:24 PDT 2023
  Reporter:  strk                   |      Owner:  strk
      Type:  enhancement            |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.4.1
 Component:  build/upgrade/install  |    Version:  3.4.x
Resolution:  invalid                |   Keywords:
Comment (by strk):
 I confirm the error with "target function already exists" is due to the
 deprecated function still being in the database, and the only reason why a
 deprecated function is still in the database is because we are re-adding
 it, which is what is happening while being affected by issue #5494:
 > ERROR:  Attempting to rename replaced function st_dwithin(text, text,
 float8) got function st_dwithin_deprecated_by_postgis_300(text, text,
 double precision) already exists in schema "public" (42723)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5493#comment:4>
