[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-69-g80064b75c
Tue Aug 29 13:27:05 PDT 2023
the project "PostGIS".
       via  80064b75c6cbef9d54ed8bcbf93984eeb884bd61 (commit)
      from  9691b2b2efd64d2303b42329360f0a8a14345afa (commit)
revisions in full, below.
commit 80064b75c6cbef9d54ed8bcbf93984eeb884bd61
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Aug 29 22:13:52 2023 +0200
    Add query creating a view using all postgis functions
    This is meant to be used to test upgrades in a more complete way.
    It's a work in progress but the idea is it will possibly be used
    for upgrade testing, which is already possible with a call like:
      cat regress/hooks/use-all-functions.sql |
      make check-regress \
        RUNTESTFLAGS="--upgrade --before-upgrade-script /dev/stdin -v" \
        TESTS=$PWD/regress/core/regress.sql
diff --git a/regress/hooks/use-all-functions.sql b/regress/hooks/use-all-functions.sql
new file mode 100644
index 000000000..b4db13ca4
--- /dev/null
+++ b/regress/hooks/use-all-functions.sql
@@ -0,0 +1,30 @@
+DO $BODY$
+DECLARE
+	rec RECORD;
+BEGIN
+	FOR rec IN
+		SELECT
+			array_agg(
+				regexp_replace(
+					regexp_replace(
+						oid::regprocedure::text,
+						'(NULL::\1'
+					',NULL::',
+					'g'
+				) || ' as f' || oid
+			) f
+		FROM pg_catalog.pg_proc
+		WHERE proname like 'st\_%'
+	LOOP
+		EXECUTE format(
+			'CREATE VIEW postgis_locking_view AS SELECT %s',
+			array_to_string(rec.f, ',')
+	END LOOP;
+END;
+$BODY$ LANGUAGE 'plpgsql';
Summary of changes:
 regress/hooks/use-all-functions.sql | 30 ++++++++++++++++++++++++++++++
 1 file changed, 30 insertions(+)
 create mode 100644 regress/hooks/use-all-functions.sql
hooks/post-receive
