[postgis-tickets] [PostGIS] #5499: ERROR: Could not drop function st_tileenvelope. You might need to drop dependant objects
PostGIS trac at osgeo.org
Tue Aug 29 14:27:45 PDT 2023
dependant objects
 Reporter:  strk     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.4.1
Component:  postgis  |    Version:  3.4.x
 Keywords:           |
 To reproduce:
 > cat regress/hooks/use-all-functions.sql | make check-regress
 RUNTESTFLAGS="--upgrade --before-upgrade-script /dev/stdin -v"
 TESTS=/dev/null
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5499>
