[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-73-gf0cd8881b
git at osgeo.org
git at osgeo.org
Tue Aug 29 15:36:43 PDT 2023
the project "PostGIS".
via f0cd8881bdaf19e0a3b083b0707791997ef9a16a (commit)
via bcf92c7d707d6930b5a6efb0016c391025755933 (commit)
from 08aaa880ac8ce4ccd6e8c6eb62f851691ec65385 (commit)
revisions in full, below.
commit f0cd8881bdaf19e0a3b083b0707791997ef9a16a
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Aug 30 00:28:11 2023 +0200
Add check-double-upgrade and check-locked-upgrade make targets
The double-upgrade test can catch the bug reported in #5494
The locked-upgrade can catch many yet-unfixed bugs like #5499
Neither of these tests are currently automatically
run by 'make check'
diff --git a/regress/runtest.mk b/regress/runtest.mk
index c051f0379..7ec77bf13 100644
--- a/regress/runtest.mk
+++ b/regress/runtest.mk
@@ -38,3 +38,15 @@ check-regress:
check-long:
$(PERL) $(top_srcdir)/regress/run_test.pl $(RUNTESTFLAGS) $(TESTS) $(TESTS_SLOW)
+.PHONY: check-double-upgrade
+check-double-upgrade:
+ $(MAKE) check-regress \
+ RUNTESTFLAGS='$(RUNTESTFLAGS) --upgrade --upgrade' \
+ TESTS=$(top_srcdir)/regress/core/regress.sql
+.PHONY: check-locked-upgrade
+check-locked-upgrade:
+ RUNTESTFLAGS="$(RUNTESTFLAGS) --upgrade --before-upgrade-script regress/hooks/use-all-functions.sql" \
commit bcf92c7d707d6930b5a6efb0016c391025755933
Date: Wed Aug 30 00:26:22 2023 +0200
Allow requesting multiple upgrades to run_test.pl
Pass multiple --upgrade switches to upgrade multiple times.
It can be used to trigger bugs with still-existing functions
being marked as deprecated.
References #5494
diff --git a/regress/run_test.pl b/regress/run_test.pl
index cb391df4c..0b502b6fe 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -98,7 +98,7 @@ GetOptions (
'verbose+' => \$VERBOSE,
'clean' => \$OPT_CLEAN,
'nodrop' => \$OPT_NODROP,
- 'upgrade' => \$OPT_UPGRADE,
+ 'upgrade+' => \$OPT_UPGRADE,
'upgrade-path=s' => \$OPT_UPGRADE_PATH,
'dumprestore' => \$OPT_DUMPRESTORE,
'nocreate' => \$OPT_NOCREATE,
@@ -433,7 +433,8 @@ if ( $OPT_DUMPRESTORE )
if ( $OPT_UPGRADE )
- print "Upgrading from postgis $libver\n";
+ my $upgradesleft = $OPT_UPGRADE;
+ print "Upgrading from postgis $libver ($upgradesleft upgrades requested)\n";
foreach my $hook (@OPT_HOOK_BEFORE_UPGRADE)
@@ -441,13 +442,16 @@ if ( $OPT_UPGRADE )
die unless load_sql_file($hook, 1);
- if ( $OPT_EXTENSIONS )
+ while ( $upgradesleft-- )
- die unless upgrade_spatial_extensions();
- else
- die unless upgrade_spatial();
+ if ( $OPT_EXTENSIONS )
+ die unless upgrade_spatial_extensions();
+ else
+ die unless upgrade_spatial();
foreach my $hook (@OPT_HOOK_AFTER_UPGRADE)
@@ -687,7 +691,8 @@ Usage: $0 [<options>] <testname> [<testname>]
Options:
-v, --verbose be verbose about failures
--nocreate do not create the regression database on start
- --upgrade source the upgrade scripts on start
+ --upgrade upgrade db before runnign tests, can be passed
+ multiple times to perform multiple upgrades.
--upgrade-path upgrade path, format <from>--<to>.
<from> can be specified as "unpackaged<version>"
to specify a script version to start from.
Summary of changes:
regress/run_test.pl | 23 ++++++++++++++---------
regress/runtest.mk | 12 ++++++++++++
2 files changed, 26 insertions(+), 9 deletions(-)
hooks/post-receive
