[postgis-tickets] [SCM] PostGIS branch stable-3.2 updated. 3.2.5-11-ga416a4415
Wed Aug 30 02:37:09 PDT 2023
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  a416a441577d012445f55108b7812f65233ce8ea (commit)
      from  bc35b390180abc6a517da1b7d9968f810cfe08ec (commit)
revisions in full, below.
commit a416a441577d012445f55108b7812f65233ce8ea
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Aug 29 17:45:50 2023 +0200
    Stop deprecating ST_DWithin(text) while not being deprecated
    Fixes availability/changed info for ST_DWithin(..geometry..)
    Add test for upgrades in presence of view using ST_DWithin(..geometry..)
    References #5494 in 3.2 branch (3.2.6dev)
diff --git a/NEWS b/NEWS
index 89a210e76..90f319052 100644
--- a/NEWS
+++ b/NEWS
@@ -7,6 +7,8 @@ Additional features are enabled if you are running GEOS 3.9+
 Proj 6.1+, and PostgreSQL 14+.
 * Bug Fixes and Enhancements *
+  - #5494, Fix double-upgrade with view using st_dwithin(text, ...)
+           (Sandro Santilli)
   - #5450, Fix macro expansion recursion on powerpc architectures.
            (Bas Couwenberg)
   - #5403, [postgis_topology] Fix ValidateTopology(bbox)
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 21e49beba..23cf2bcee 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -4359,9 +4359,10 @@ CREATE OR REPLACE FUNCTION ST_LineCrossingDirection(line1 geometry, line2 geomet
 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
 	_COST_HIGH;
--- Availability: 1.3.4
--- Replaces ST_DWithin(text, text, float8) deprecated in 3.0.0
-CREATE OR REPLACE FUNCTION ST_DWithin(geom1 geometry, geom2 geometry,float8)
+-- Availability: 1.3.0
+-- Changed: 2.0.0 added parameter names
+-- TODO: encode deprecation of the version with no parameter names ?
+CREATE OR REPLACE FUNCTION ST_DWithin(geom1 geometry, geom2 geometry, float8)
 	RETURNS boolean
 	AS 'MODULE_PATHNAME', 'LWGEOM_dwithin'
 	SUPPORT postgis_index_supportfn
diff --git a/regress/hooks/hook-before-upgrade.sql b/regress/hooks/hook-before-upgrade.sql
index f590f9401..4c620266a 100644
--- a/regress/hooks/hook-before-upgrade.sql
+++ b/regress/hooks/hook-before-upgrade.sql
@@ -67,13 +67,16 @@ SELECT
 	ST_AsKML(g2) as geography_askml
 FROM upgrade_test;
--- Add view using ST_DWithin function
--- NOTE: 3.0.0 changed them to add default params
+-- Add view using ST_DWithin functions
+-- See https://trac.osgeo.org/postgis/ticket/5494
 CREATE VIEW upgrade_view_test_dwithin AS
 SELECT
-	ST_DWithin(g1::text, g1::text, 1) as text_dwithin,
-	ST_DWithin(g2, g2, 1) as geography_dwithin
-FROM upgrade_test;
+	ST_DWithin(NULL::text, NULL::text, NULL::float8) as text_dwithin,
+	-- Available since 1.5.0, changed in 3.0.0 to add optional 4th use_spheroid param
+	ST_DWithin(NULL::geography, NULL::geography, NULL::float8) as geography_dwithin,
+	-- Available since 1.3.0
+	ST_DWithin(NULL::geometry, NULL::geometry, NULL::float8) as geometry_dwithin
 -- Add view using ST_ClusterKMeans windowing function
 -- NOTE: 3.2.0 changed it to add max_radius parameter
Summary of changes:
 NEWS                                  |  2 ++
 postgis/postgis.sql.in                |  7 ++++---
 regress/hooks/hook-before-upgrade.sql | 13 ++++++++-----
 3 files changed, 14 insertions(+), 8 deletions(-)
hooks/post-receive
