[postgis-tickets] [PostGIS] #5494: st_dwithin(text, text, float8) is marked as deprecated and installed by the same postgis version
PostGIS trac at osgeo.org
Wed Aug 30 02:38:47 PDT 2023
#5494: st_dwithin(text,text,float8) is marked as deprecated and installed by the
  Reporter:  strk      |      Owner:  pramsey
      Type:  defect    |     Status:  closed
  Priority:  critical  |  Milestone:  PostGIS 3.1.10
 Component:  postgis   |    Version:  master
Resolution:  fixed     |   Keywords:  upgrade, deprecation, st_dwithin
Changes (by Sandro Santilli <strk@…>):
 * status:  reopened => closed
 * resolution:   => fixed
Comment:
 In [changeset:"bb104ff9738981f597f3b7775033e8d8f7e6c4af/git" bb104ff/git]:
 {{{#!CommitTicketReference repository="git"
 revision="bb104ff9738981f597f3b7775033e8d8f7e6c4af"
 Stop deprecating ST_DWithin(text) while not being deprecated
 Fixes availability/changed info for ST_DWithin(..geometry..)
 Add test for upgrades in presence of view using ST_DWithin(..geometry..)
 Closes #5494 in 3.1 branch (3.1.10dev)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5494#comment:12>
