[postgis-tickets] [PostGIS] #5508: ERROR: cannot drop function st_makeemptyraster(integer, integer, double precision, double precision, double precision, double precision, double precision, double precision, integer) because other objects depend on it
PostGIS trac at osgeo.org
Wed Aug 30 08:05:53 PDT 2023
#5508: ERROR:  cannot drop function st_makeemptyraster(integer,integer,double
precision,double precision,double precision,double precision,double
precision,double precision,integer) because other objects depend on it
 Reporter:  strk                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 3.4.1
Component:  build/upgrade/install  |    Version:  3.4.x
 Keywords:  raster                 |
 Spotted via make -C raster/test/regress/ check-locked-upgrade
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5508>
