[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-84-g83c9005b4
Wed Aug 30 09:11:11 PDT 2023
the project "PostGIS".
       via  83c9005b495cbc1c54facf017db331a8a4d635d7 (commit)
      from  327c3ec729107c2470fb1256fdac8e9c350159c7 (commit)
revisions in full, below.
commit 83c9005b495cbc1c54facf017db331a8a4d635d7
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Aug 30 18:10:56 2023 +0200
    Fix upgrade with objects using ST_MapAlgebraFCT
    Also adds availability info to the function signatures.
    References #5500 in master branch (3.5.0dev)
diff --git a/raster/rt_pg/rtpostgis.sql.in b/raster/rt_pg/rtpostgis.sql.in
index ccb2863eb..2efecbbef 100644
--- a/raster/rt_pg/rtpostgis.sql.in
+++ b/raster/rt_pg/rtpostgis.sql.in
@@ -2349,6 +2349,7 @@ CREATE OR REPLACE FUNCTION st_mapalgebraexpr(rast raster, pixeltype text, expres
     LANGUAGE 'sql' IMMUTABLE PARALLEL SAFE;
 -- All arguments supplied, use the C implementation.
+-- Availability: 2.0.0
 CREATE OR REPLACE FUNCTION st_mapalgebrafct(rast raster, band integer,
         pixeltype text, onerastuserfunc regprocedure, variadic args text[])
     RETURNS raster
@@ -2356,6 +2357,7 @@ CREATE OR REPLACE FUNCTION st_mapalgebrafct(rast raster, band integer,
     LANGUAGE 'c' IMMUTABLE PARALLEL SAFE;
 -- Variant 1: missing user args
         pixeltype text, onerastuserfunc regprocedure)
     RETURNS raster
@@ -2363,6 +2365,7 @@ CREATE OR REPLACE FUNCTION st_mapalgebrafct(rast raster, band integer,
 -- Variant 2: missing pixeltype; default to pixeltype of rast
     RETURNS raster
@@ -2370,6 +2373,7 @@ CREATE OR REPLACE FUNCTION st_mapalgebrafct(rast raster, band integer,
 -- Variant 3: missing pixeltype and user args; default to pixeltype of rast
     RETURNS raster
@@ -2377,6 +2381,7 @@ CREATE OR REPLACE FUNCTION st_mapalgebrafct(rast raster, band integer,
 -- Variant 4: missing band; default to band 1
 CREATE OR REPLACE FUNCTION st_mapalgebrafct(rast raster, pixeltype text,
     RETURNS raster
@@ -2384,6 +2389,7 @@ CREATE OR REPLACE FUNCTION st_mapalgebrafct(rast raster, pixeltype text,
 -- Variant 5: missing band and user args; default to band 1
     RETURNS raster
@@ -2391,6 +2397,7 @@ CREATE OR REPLACE FUNCTION st_mapalgebrafct(rast raster, pixeltype text,
 -- Variant 6: missing band, and pixeltype; default to band 1, pixeltype of rast.
 CREATE OR REPLACE FUNCTION st_mapalgebrafct(rast raster, onerastuserfunc regprocedure,
     RETURNS raster
@@ -2398,6 +2405,7 @@ CREATE OR REPLACE FUNCTION st_mapalgebrafct(rast raster, onerastuserfunc regproc
 -- Variant 7: missing band, pixeltype, and user args; default to band 1, pixeltype of rast.
 CREATE OR REPLACE FUNCTION st_mapalgebrafct(rast raster, onerastuserfunc regprocedure)
     RETURNS raster
     AS $$ SELECT @extschema at .ST_mapalgebrafct($1, 1, NULL, $2, NULL) $$
@@ -2430,6 +2438,7 @@ CREATE OR REPLACE FUNCTION st_mapalgebraexpr(
 	AS $$ SELECT @extschema at .ST_mapalgebraexpr($1, 1, $2, 1, $3, $4, $5, $6, $7, $8) $$
 	rast1 raster, band1 integer,
 	rast2 raster, band2 integer,
@@ -2441,11 +2450,13 @@ CREATE OR REPLACE FUNCTION st_mapalgebrafct(
 	AS 'MODULE_PATHNAME', 'RASTER_mapAlgebra2'
 	rast1 raster,
 	rast2 raster,
 	tworastuserfunc regprocedure,
-	pixeltype text DEFAULT NULL, extenttype text DEFAULT 'INTERSECTION',
+	pixeltype text DEFAULT NULL,
+	extenttype text DEFAULT 'INTERSECTION',
 	VARIADIC userargs text[] DEFAULT NULL
 	RETURNS raster
diff --git a/raster/rt_pg/rtpostgis_drop.sql.in b/raster/rt_pg/rtpostgis_drop.sql.in
index ad5cdf537..ea65700d5 100644
--- a/raster/rt_pg/rtpostgis_drop.sql.in
+++ b/raster/rt_pg/rtpostgis_drop.sql.in
@@ -76,6 +76,8 @@ DROP FUNCTION IF EXISTS st_aspect(raster, integer, text, boolean);
 DROP FUNCTION IF EXISTS ST_Intersection(raster,raster, integer, integer);
 DROP FUNCTION IF EXISTS ST_Intersection(geometry,raster);
+-- Never made it into 2.0.0, see https://trac.osgeo.org/postgis/ticket/5500
+DROP FUNCTION IF EXISTS  ST_MapAlgebraFct(raster, raster, regprocedure, VARIADIC text[]);
 -- Removed in 2.1.0
 DROP FUNCTION IF EXISTS _st_mapalgebra4unionfinal1(raster);
 -- Removed in 2.1.0
diff --git a/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in b/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
index 0b32f5b13..ee0e1b549 100644
--- a/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
+++ b/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
@@ -147,22 +147,8 @@ DROP FUNCTION IF EXISTS ST_MapAlgebra(raster, pixeltype text, expression text, n
 --signatures or arg names changed
 DROP FUNCTION IF EXISTS ST_MapAlgebraExpr(raster, integer, text, text, text);
 DROP FUNCTION IF EXISTS ST_MapAlgebraExpr(raster, text, text, text);
-DROP FUNCTION IF EXISTS ST_MapalgebraFct(raster, regprocedure);
-DROP FUNCTION IF EXISTS ST_MapAlgebraFct(raster, text, regprocedure, VARIADIC text[]);
-DROP FUNCTION IF EXISTS ST_MapAlgebraFct(raster, text, regprocedure);
-DROP FUNCTION IF EXISTS ST_MapAlgebraFct(raster, regprocedure, VARIADIC text[]);
-DROP FUNCTION IF EXISTS ST_MapAlgebraFct(raster, integer, regprocedure, variadic text[]);
-DROP FUNCTION IF EXISTS ST_MapAlgebraFct(raster, integer, text, regprocedure, VARIADIC text[]);
-DROP FUNCTION IF EXISTS ST_MapAlgebraFct(raster, integer, text, regprocedure);
-DROP FUNCTION IF EXISTS ST_MapalgebraFct(raster, integer, regprocedure);
-DROP FUNCTION IF EXISTS ST_MapAlgebraFct(raster, raster, regprocedure, text, text, VARIADIC text[]);
-DROP FUNCTION IF EXISTS ST_MapAlgebraFct(raster, integer, raster, integer, regprocedure, text, text, VARIADIC text[]);
 DROP FUNCTION IF EXISTS ST_MapAlgebraFctNgb(raster, integer, text, integer, integer, regprocedure, text,  VARIADIC text[]);
---dropped functions
-DROP FUNCTION IF EXISTS  ST_MapAlgebraFct(raster, raster, regprocedure, VARIADIC text[]);
 --added extra parameter so these are obsolete --
 DROP FUNCTION IF EXISTS ST_AsRaster(geometry , integer , integer , double precision , double precision , text , double precision , double precision , double precision , double precision );
 DROP FUNCTION IF EXISTS ST_AsRaster(geometry , integer , integer , text[] , double precision[] , double precision[] , double precision , double precision , double precision , double precision );
Summary of changes:
 raster/rt_pg/rtpostgis.sql.in                 | 13 ++++++++++++-
 raster/rt_pg/rtpostgis_drop.sql.in            |  2 ++
 raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in | 14 --------------
 3 files changed, 14 insertions(+), 15 deletions(-)
hooks/post-receive
