[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-86-ge9df66644
Wed Aug 30 12:38:09 PDT 2023
the project "PostGIS".
       via  e9df66644c4a2d40b10f1946a32efba23c3041af (commit)
      from  b3925e4e95f90f50db4cb6e5c1d4c2210c6eea93 (commit)
revisions in full, below.
commit e9df66644c4a2d40b10f1946a32efba23c3041af
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Aug 30 21:20:40 2023 +0200
    Skip all problematic raster functions from locking view
    Have dronie/woodie run locked upgrade test also for raster
    References #5497
    References #5516
diff --git a/ci/dronie/postgis_regress.sh b/ci/dronie/postgis_regress.sh
index 9f9d66db8..32becff59 100644
--- a/ci/dronie/postgis_regress.sh
+++ b/ci/dronie/postgis_regress.sh
@@ -30,12 +30,7 @@ psql -c "select version()" template1
 RUNTESTFLAGS=-v make check
 RUNTESTFLAGS=-v make check-double-upgrade
-RUNTESTFLAGS=-v make -C regress check-locked-upgrade
-RUNTESTFLAGS=-v make -C topology/test check-locked-upgrade
-# This is blocked by https://trac.osgeo.org/postgis/ticket/5516
-#RUNTESTFLAGS=-v make -C raster/test/regress check-locked-upgrade
+RUNTESTFLAGS=-v make check-locked-upgrade
 # Install
diff --git a/regress/hooks/use-all-functions.sql b/regress/hooks/use-all-functions.sql
index 05805cb1f..f7276c8a0 100644
--- a/regress/hooks/use-all-functions.sql
+++ b/regress/hooks/use-all-functions.sql
@@ -49,10 +49,18 @@ BEGIN
 			,'st_value' -- https://trac.osgeo.org/postgis/ticket/5513
 			,'st_georeference' -- https://trac.osgeo.org/postgis/ticket/5514
 			,'st_summarystats' -- https://trac.osgeo.org/postgis/ticket/5515
+			,'st_approxsummarystats' -- GENERIC https://trac.osgeo.org/postgis/ticket/5516
+			,'st_valuecount' -- GENERIC https://trac.osgeo.org/postgis/ticket/5516
+			,'st_nearestvalue' -- GENERIC https://trac.osgeo.org/postgis/ticket/5516
+			,'st_neighborhood' -- GENERIC https://trac.osgeo.org/postgis/ticket/5516
+			,'st_hillshade' -- GENERIC https://trac.osgeo.org/postgis/ticket/5516
+			,'st_setvalue' -- GENERIC https://trac.osgeo.org/postgis/ticket/5516
 		-- Skip function known to be problematic
 		AND oid::regprocedure::text NOT IN (
 			'st_polygon(raster,integer)' -- https://trac.osgeo.org/postgis/ticket/5507
+			,'st_intersection(raster,integer,geometry)' -- GENERIC https://trac.osgeo.org/postgis/ticket/5516
+			,'st_intersection(raster,geometry)' -- GENERIC https://trac.osgeo.org/postgis/ticket/5516
 		-- Skip functions taking polymorphic arguments (anyelement)
 		-- as those ones would need us to cast to some real type.
Summary of changes:
 ci/dronie/postgis_regress.sh        | 7 +------
 regress/hooks/use-all-functions.sql | 8 ++++++++
 2 files changed, 9 insertions(+), 6 deletions(-)
hooks/post-receive
