[postgis-tickets] [PostGIS] #5519: ERROR: cannot drop function st_setvalue(raster, integer, geometry, double precision) because other objects depend on it
PostGIS trac at osgeo.org
Thu Aug 31 05:53:19 PDT 2023
#5519: ERROR:  cannot drop function st_setvalue(raster,integer,geometry,double
 Reporter:  strk    |      Owner:  robe
     Type:  defect  |     Status:  new
 Priority:  medium  |  Milestone:  PostGIS 3.4.1
Component:  raster  |    Version:  3.4.x
 Keywords:          |
 To reproduce, comment out the `st_setvalue` lins in regress/hooks/use-all-
 functions.sql and run:
 > make -C raster/test/regress check-locked-upgrade RUNTESTFLAGS='-v'
 The current signature is:
 raster/rt_pg/rtpostgis.sql.in:5077:
 CREATE OR REPLACE FUNCTION ST_SetValue(
     rast raster, nband integer,
     geom geometry, newvalue double precision
 That signature was the same up to 2.1.0
 but in 2.0 has the geometry attribute called 'pt' instead of 'geom'
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5519>
