[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-96-gfa9453e23
Thu Aug 31 22:27:20 PDT 2023
the project "PostGIS".
       via  fa9453e23604f6930f6aa22dac44da3f22df144d (commit)
      from  2fc99d743a914ea642e272f3fe06ff4b76822cc8 (commit)
revisions in full, below.
commit fa9453e23604f6930f6aa22dac44da3f22df144d
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Sep 1 01:27:12 2023 -0400
    Try to fix parse issue with chinese file
diff --git a/doc/po/zh_Hans/using_postgis_dataman.xml.po b/doc/po/zh_Hans/using_postgis_dataman.xml.po
index 0309adef3..596a4ceca 100644
--- a/doc/po/zh_Hans/using_postgis_dataman.xml.po
+++ b/doc/po/zh_Hans/using_postgis_dataman.xml.po
@@ -1402,8 +1402,8 @@ msgid ""
 "query you run; the number of vertices is huge, and tests (distance, "
 "containment) have to traverse the vertex list at least once and sometimes N "
 "times (with N being the number of vertices in the other candidate feature)."
-msgstr "
-因为多边形大得离谱。大面积不好有两个原因 一个原因是边界框很大,因此无论您运行什么查询,索引都倾向于拉取特征。"
+msgstr ""
+"因为多边形大得离谱。大面积不好有两个原因 一个原因是边界框很大,因此无论您运行什么查询,索引都倾向于拉取特征。"
 "另一个原因是顶点计数很大,并且测试(距离、包含)函数必须至少遍历顶点一次,通常为 N(其中 N 是另一个要素的顶点计数)。"
 #. Tag: para
Summary of changes:
 doc/po/zh_Hans/using_postgis_dataman.xml.po | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
