[SCM] PostGIS branch master updated. 3.4.0rc1-826-g89b31d970
Fri Dec 1 08:08:27 PST 2023
the project "PostGIS".
       via  89b31d970de2975320c4a4b76c9dd5a0760b51d8 (commit)
      from  8b2c090a88788bfc9dc266200fefe33de50b5c98 (commit)
revisions in full, below.
commit 89b31d970de2975320c4a4b76c9dd5a0760b51d8
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Dec 1 08:08:15 2023 -0800
    Fix crash on multipoint repeated point with empty, #5629
diff --git a/liblwgeom/lwgeom.c b/liblwgeom/lwgeom.c
index 6f2eb9764..6a1ec79cd 100644
--- a/liblwgeom/lwgeom.c
+++ b/liblwgeom/lwgeom.c
@@ -1575,7 +1575,12 @@ cmp_point_x(const void *pa, const void *pb)
 	const POINT2D *pt1 = getPoint2d_cp(p1->point, 0);
 	const POINT2D *pt2 = getPoint2d_cp(p2->point, 0);
-	return (pt1->x > pt2->x) ? 1 : ((pt1->x < pt2->x) ? -1 : 0);
+	if (pt1 && pt2)
+		return (pt1->x > pt2->x) ? 1 : ((pt1->x < pt2->x) ? -1 : 0);
+	if (pt1) return -1;
+	if (pt2) return 1;
+	return 0;
 static int
@@ -1587,7 +1592,12 @@ cmp_point_y(const void *pa, const void *pb)
-	return (pt1->y > pt2->y) ? 1 : ((pt1->y < pt2->y) ? -1 : 0);
+	if (pt1 && pt2)
+		return (pt1->y > pt2->y) ? 1 : ((pt1->y < pt2->y) ? -1 : 0);
+	return 0;
 int
@@ -1650,6 +1660,7 @@ lwgeom_remove_repeated_points_in_place(LWGEOM *geom, double tolerance)
 					continue;
 				const POINT2D *pti = getPoint2d_cp(mpt->geoms[i]->point, 0);
+				if (!pti) continue;
 				/* check upcoming points if they're within tolerance of current one */
 				for (uint32_t j = i + 1; j < mpt->ngeoms; j++)
@@ -1658,6 +1669,7 @@ lwgeom_remove_repeated_points_in_place(LWGEOM *geom, double tolerance)
 						continue;
 					const POINT2D *ptj = getPoint2d_cp(mpt->geoms[j]->point, 0);
+					if (!ptj) continue;
 					/* check that the point is in the strip of tolerance around the point */
 					if ((dim ? ptj->x - pti->x : ptj->y - pti->y) > tolerance)
@@ -1673,6 +1685,17 @@ lwgeom_remove_repeated_points_in_place(LWGEOM *geom, double tolerance)
+			/* null out empties */
+			for (uint32_t j = 0; j < mpt->ngeoms; j++)
+				if (mpt->geoms[j] && lwpoint_is_empty(mpt->geoms[j]))
+					lwpoint_free(mpt->geoms[j]);
+					mpt->geoms[j] = NULL;
+					geometry_modified = LW_TRUE;
 			/* compactify array of points */
 			uint32_t i = 0;
Summary of changes:
 liblwgeom/lwgeom.c | 27 +++++++++++++++++++++++++--
 1 file changed, 25 insertions(+), 2 deletions(-)
hooks/post-receive
