[SCM] PostGIS branch master updated. 3.4.0rc1-827-gc1dbf8ef0
Fri Dec 1 15:41:53 PST 2023
the project "PostGIS".
       via  c1dbf8ef0007f8230b1ec76e4b3f9d079647dcb2 (commit)
      from  89b31d970de2975320c4a4b76c9dd5a0760b51d8 (commit)
revisions in full, below.
commit c1dbf8ef0007f8230b1ec76e4b3f9d079647dcb2
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Dec 1 15:32:28 2023 -0800
    Correctly handle distances between collections with empty elements, references #5604
diff --git a/liblwgeom/measures.c b/liblwgeom/measures.c
index 3e255f9ec..b22b2cca1 100644
--- a/liblwgeom/measures.c
+++ b/liblwgeom/measures.c
@@ -299,7 +299,7 @@ lw_dist2d_recursive(const LWGEOM *lwg1, const LWGEOM *lwg2, DISTPTS *dl)
 			g1 = (LWGEOM *)lwg1;
 		if (lwgeom_is_empty(g1))
-			return LW_TRUE;
+			continue;
 		if (lw_dist2d_is_collection(g1))
@@ -329,10 +329,9 @@ lw_dist2d_recursive(const LWGEOM *lwg1, const LWGEOM *lwg2, DISTPTS *dl)
 			if (!g2->bbox)
 				lwgeom_add_bbox(g2);
-			/* If one of geometries is empty, return. True here only means continue searching. False would
-			 * have stopped the process*/
+			/* If one of geometries is empty, skip */
 			if (lwgeom_is_empty(g1) || lwgeom_is_empty(g2))
-				return LW_TRUE;
+				continue;
 			if ((dl->mode != DIST_MAX) && (!lw_dist2d_check_overlap(g1, g2)) &&
 			    (g1->type == LINETYPE || g1->type == POLYGONTYPE || g1->type == TRIANGLETYPE) &&
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 273695cae..2c3f7e3ec 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1517,3 +1517,12 @@ FROM (VALUES
     ('MULTIPOLYGON(((-357 477,-392 574,-378 574,-357 477)))'::geometry),
     ('MULTIPOLYGON(((-357 477,-392 574,-378 574,-357 477)))'::geometry))
     AS geoms(geom);
+SELECT '#5604',
+ ST_Distance(a2, a1),
+ ST_AsText(ST_ClosestPoint(a2, a1)),
+ ST_Distance(a1, a2),
+ ST_AsText(ST_ClosestPoint(a1, a2))
+FROM
+ST_GeomFromText('MULTIPOINT((-2 0), EMPTY)') AS a1,
+ST_GeomFromText('MULTIPOINT((1 0),(0 0))') AS a2;
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index a701e6d6b..b9f3cf854 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -469,3 +469,4 @@ ERROR:  Geometry contains invalid coordinates
 #5378|4269
 #5627|t
+#5604|2|POINT(0 0)|2|POINT(-2 0)
Summary of changes:
 liblwgeom/measures.c          | 7 +++----
 regress/core/tickets.sql      | 9 +++++++++
 regress/core/tickets_expected | 1 +
 3 files changed, 13 insertions(+), 4 deletions(-)
hooks/post-receive
