[SCM] PostGIS branch master updated. 3.4.0rc1-829-g4338f0b59
Fri Dec 1 17:41:28 PST 2023
the project "PostGIS".
       via  4338f0b59c47d651347564c74003598b4c55b8c1 (commit)
      from  38d9c69f1dd5c0061d254d190aeb38795edea9d4 (commit)
revisions in full, below.
commit 4338f0b59c47d651347564c74003598b4c55b8c1
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Dec 1 16:15:41 2023 -0500
    Allow ST_RemoveRepeatedPoints to be tested
    now that it is fixed
diff --git a/doc/xsl/postgis_gardentest.sql.xsl b/doc/xsl/postgis_gardentest.sql.xsl
index 9f15c8e49..f7a09e657 100644
--- a/doc/xsl/postgis_gardentest.sql.xsl
+++ b/doc/xsl/postgis_gardentest.sql.xsl
@@ -13,7 +13,7 @@
 	<xsl:output method="text" />
 	<xsl:variable name='testversion'>3.5.0</xsl:variable>
 	<xsl:variable name='fnexclude14'>AddGeometryColumn DropGeometryColumn DropGeometryTable</xsl:variable>
-	<xsl:variable name='fnexclude'>AddGeometryColumn DropGeometryColumn DropGeometryTable CG_Visibility CG_YMonotonePartition ST_RemoveRepeatedPoints ST_AlphaShape ST_OptimalAlphaShape</xsl:variable>
+	<xsl:variable name='fnexclude'>AddGeometryColumn DropGeometryColumn DropGeometryTable CG_Visibility CG_YMonotonePartition ST_AlphaShape ST_OptimalAlphaShape</xsl:variable>
 	<!--This is just a place holder to state functions not supported or tested separately -->
 	<xsl:variable name='var_srid'>3395</xsl:variable>
Summary of changes:
 doc/xsl/postgis_gardentest.sql.xsl | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
