[PostGIS] #5636: berrie 32bit failing on garden tests
PostGIS trac at osgeo.org
Sun Dec 3 15:07:02 PST 2023
 Reporter:  robe          |      Owner:  robe
     Type:  defect        |     Status:  new
 Priority:  medium        |  Milestone:  Website Management, Bots
Component:  QA/buildbots  |    Version:  master
 Keywords:                |
 This one I need to rerun.  berrie64 is still doing garden testing and I
 think has gone passed this test
 Given this is several minors behind probably not much of a concern.  I'll
 up to pg16 and rebuild pg15 to see if issue still continues
 -------------- Dependencies --------------
 17:13:42   GEOS config:
 /home/jenkins/workspace/geos/rel-3.13.0/bin/geos-config
 17:13:42   GEOS version:         3.13.0dev
 17:13:42   GDAL config:          /usr/bin/gdal-config
 17:13:42   GDAL version:         3.2.2
 17:13:42   PostgreSQL config:
 /home/jenkins/workspace/pg/label/berrie/rel/pg15w32/bin/pg_config
 17:13:42   PostgreSQL version:   PostgreSQL 15.0
 17:13:42   PROJ4 version:        72
 17:13:42   Libxml2 config:       /usr/bin/xml2-config
 17:13:42   Libxml2 version:      2.9.10
 17:13:42   JSON-C support:       yes
 17:13:42   protobuf support:     no
 17:13:42   PCRE support:         Version 1
 17:13:42   Perl:                 /usr/bin/perl
 17:13:42
 SELECT ST_MakePolygon(foo1.the_geom,
                                                 ARRAY[foo2.the_geom]
                                         ) As result,
 ST_AsText(foo1.the_geom) As ref1_geom, ST_AsText(foo2.the_geom) As
 ref2_geom
         FROM (
                 (SELECT ST_GeomFromText('LINESTRING ZM (1 2 3 NaN,3 4 10
 5,5 6 NaN NaN)',4326) As the_geom) ) As foo1 CROSS JOIN ((SELECT CAST(Null
 As geometry) As the_geom)) As foo2 LIMIT 10;
 On my system, the above returns the expected:
 ERROR:  Hole 0 is not a line
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5636>
