[SCM] PostGIS branch stable-3.0 updated. 3.0.10-11-g190d92ad5
Mon Dec 4 11:06:21 PST 2023
the project "PostGIS".
The branch, stable-3.0 has been updated
       via  190d92ad5acf13644a7c781623b6534a3f9a7e14 (commit)
       via  b4e27c1a6bf50cec169f6e2e5b0607bbedc010a9 (commit)
       via  c5d91e6b90a542b60184904458967a57f6b9971d (commit)
      from  0437cc0f206c76b2ac428656fa98729468c451f1 (commit)
revisions in full, below.
commit 190d92ad5acf13644a7c781623b6534a3f9a7e14
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Dec 4 10:58:24 2023 -0800
    Use WKB in NaN-based regression test, references #5635
diff --git a/regress/core/split.sql b/regress/core/split.sql
index a1087e171..1fd9edfc4 100644
--- a/regress/core/split.sql
+++ b/regress/core/split.sql
@@ -108,10 +108,12 @@ select '87', ST_AsEWKT(ST_Split('SRID=4326;LINESTRING EMPTY', 'SRID=4326;POINT(0
 -- https://trac.osgeo.org/postgis/ticket/5635 (split by nan input)
-SELECT '#5635a', ST_Split('LINESTRING Z (1 2 NaN,3 4 10,5 6 NaN)'::geometry
-					,'MULTIPOINT(EMPTY,2 1,2 4, 4 5)'::geometry);
+SELECT '#5635a', ST_Split(
+	'010200008003000000000000000000F03F0000000000000040000000000000F87F00000000000008400000000000001040000000000000244000000000000014400000000000001840000000000000F87F'::geometry
+	,'0104000000040000000101000000000000000000F87F000000000000F87F01010000000000000000000040000000000000F03F010100000000000000000000400000000000001040010100000000000000000010400000000000001440'::geometry);
 -- https://trac.osgeo.org/postgis/ticket/5635 (split by nan blade)
-SELECT '#5635b', ST_Split('LINESTRING Z (1 2 1,3 4 10,5 6 3)'::geometry
-					,'MULTIPOINT(1 NaN,2 1,2 4, 4 5)'::geometry);
+SELECT '#5635b', ST_Split(
+	'010200008003000000000000000000F03F0000000000000040000000000000F03F000000000000084000000000000010400000000000002440000000000000144000000000000018400000000000000840'::geometry
+	,'0104000000040000000101000000000000000000F03F000000000000F87F01010000000000000000000040000000000000F03F010100000000000000000000400000000000001040010100000000000000000010400000000000001440'::geometry);
 -- TODO: split line by collapsed line
commit b4e27c1a6bf50cec169f6e2e5b0607bbedc010a9
Date:   Mon Dec 4 09:50:44 2023 -0800
    News item for #5635
diff --git a/NEWS b/NEWS
index 47256754b..3ee229606 100644
--- a/NEWS
+++ b/NEWS
@@ -7,6 +7,7 @@ xxxx/xx/xx
           in ST_SetPoint (Regina Obe)
  - #5627, Handling of EMPTY components in PiP check (Paul Ramsey)
  - #5604, Handle distance between collections with empty elements (Paul Ramsey)
+ - #5635, Handle NaN points in ST_Split (Regina Obe)
 PostGIS 3.0.10
commit c5d91e6b90a542b60184904458967a57f6b9971d
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Dec 3 17:09:26 2023 -0500
    Prevent NaN and infinite coordinates
    in input and blade geometries of ST_Split
    References #5635 for PostGIS 3.5.0
diff --git a/postgis/lwgeom_geos.c b/postgis/lwgeom_geos.c
index f06826189..21cbdbd84 100644
--- a/postgis/lwgeom_geos.c
+++ b/postgis/lwgeom_geos.c
@@ -3192,6 +3192,19 @@ Datum ST_Split(PG_FUNCTION_ARGS)
 	lwgeom_in = lwgeom_from_gserialized(in);
 	lwblade_in = lwgeom_from_gserialized(blade_in);
+	if (!lwgeom_isfinite(lwgeom_in))
+		lwpgerror("Input Geometry contains invalid coordinates");
+		PG_RETURN_NULL();
+	if (!lwgeom_isfinite(lwblade_in))
+		lwpgerror("Blade Geometry contains invalid coordinates");
+		PG_RETURN_NULL();
 	lwgeom_out = lwgeom_split(lwgeom_in, lwblade_in);
 	lwgeom_free(lwgeom_in);
 	lwgeom_free(lwblade_in);
index 2374026cc..a1087e171 100644
@@ -107,4 +107,11 @@ select '86', ST_AsEWKT(ST_Split(
 select '87', ST_AsEWKT(ST_Split('SRID=4326;LINESTRING EMPTY', 'SRID=4326;POINT(0 1)'));
+-- https://trac.osgeo.org/postgis/ticket/5635 (split by nan input)
+SELECT '#5635a', ST_Split('LINESTRING Z (1 2 NaN,3 4 10,5 6 NaN)'::geometry
+					,'MULTIPOINT(EMPTY,2 1,2 4, 4 5)'::geometry);
+-- https://trac.osgeo.org/postgis/ticket/5635 (split by nan blade)
+SELECT '#5635b', ST_Split('LINESTRING Z (1 2 1,3 4 10,5 6 3)'::geometry
+					,'MULTIPOINT(1 NaN,2 1,2 4, 4 5)'::geometry);
diff --git a/regress/core/split_expected b/regress/core/split_expected
index e03adcd1f..4bf7bdac2 100644
--- a/regress/core/split_expected
+++ b/regress/core/split_expected
@@ -29,3 +29,5 @@ ERROR:  Splitter line has linear intersection with input
 85|SRID=3;GEOMETRYCOLLECTION(LINESTRING(1 -2,1 -1),LINESTRING(1 -1,1 1,3 1),LINESTRING(3 1,4 1))
 86|SRID=3;GEOMETRYCOLLECTION(LINESTRING(8 0,10 0),LINESTRING(0 0,5 0),LINESTRING(5 0,8 0),LINESTRING(5 0,5 5),LINESTRING(5 -2,5 0),LINESTRING(5 -5,5 -2),LINESTRING(8 20,10 20),LINESTRING(2 20,5 20),LINESTRING(0 20,2 20),LINESTRING(5 20,8 20))
 87|SRID=4326;GEOMETRYCOLLECTION(LINESTRING EMPTY)
+ERROR:  Input Geometry contains invalid coordinates
+ERROR:  Blade Geometry contains invalid coordinates
Summary of changes:
 NEWS                        |  1 +
 postgis/lwgeom_geos.c       | 13 +++++++++++++
 regress/core/split.sql      |  9 +++++++++
 regress/core/split_expected |  2 ++
 4 files changed, 25 insertions(+)
hooks/post-receive
