[SCM] PostGIS branch stable-3.4 updated. 3.4.1-14-g503c3778e
Mon Dec 4 11:06:51 PST 2023
the project "PostGIS".
The branch, stable-3.4 has been updated
       via  503c3778e72f54c0de3bf294c08cc9a35b8c4893 (commit)
       via  57ce3c978663355a55e613f6fb02446c22ecb600 (commit)
       via  c1a0c55d70e26f19e534fd70b7cc1c8416b16abe (commit)
       via  f45df01f77442e9e22c431b2d9a8deef7825d799 (commit)
      from  342d74200ff38e00c383068cd4a2387f10eaf981 (commit)
revisions in full, below.
commit 503c3778e72f54c0de3bf294c08cc9a35b8c4893
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Dec 4 09:47:54 2023 -0800
    News item for #5635
diff --git a/NEWS b/NEWS
index 638592a20..5e750cdde 100644
--- a/NEWS
+++ b/NEWS
@@ -12,6 +12,7 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.4.1+ is needed.
  - #5627, Handling of EMPTY components in PiP check (Paul Ramsey)
  - #5629, Handling EMPTY components in repeated point removal (Paul Ramsey)
  - #5604, Handle distance between collections with empty elements (Paul Ramsey)
+ - #5635, Handle NaN points in ST_Split (Regina Obe)
 * Bug Fixes and Enhancments *
commit 57ce3c978663355a55e613f6fb02446c22ecb600
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Dec 3 17:09:26 2023 -0500
    Prevent NaN and infinite coordinates
    in input and blade geometries of ST_Split
    References #5635 for PostGIS 3.5.0
diff --git a/postgis/lwgeom_geos.c b/postgis/lwgeom_geos.c
index 900c561e7..8871d781e 100644
--- a/postgis/lwgeom_geos.c
+++ b/postgis/lwgeom_geos.c
@@ -3403,6 +3403,19 @@ Datum ST_Split(PG_FUNCTION_ARGS)
 	lwgeom_in = lwgeom_from_gserialized(in);
 	lwblade_in = lwgeom_from_gserialized(blade_in);
+	if (!lwgeom_isfinite(lwgeom_in))
+		lwpgerror("Input Geometry contains invalid coordinates");
+		PG_RETURN_NULL();
+	if (!lwgeom_isfinite(lwblade_in))
+		lwpgerror("Blade Geometry contains invalid coordinates");
+		PG_RETURN_NULL();
 	lwgeom_out = lwgeom_split(lwgeom_in, lwblade_in);
 	lwgeom_free(lwgeom_in);
 	lwgeom_free(lwblade_in);
diff --git a/regress/core/split.sql b/regress/core/split.sql
index 2374026cc..a1087e171 100644
--- a/regress/core/split.sql
+++ b/regress/core/split.sql
@@ -107,4 +107,11 @@ select '86', ST_AsEWKT(ST_Split(
 select '87', ST_AsEWKT(ST_Split('SRID=4326;LINESTRING EMPTY', 'SRID=4326;POINT(0 1)'));
+-- https://trac.osgeo.org/postgis/ticket/5635 (split by nan input)
+SELECT '#5635a', ST_Split('LINESTRING Z (1 2 NaN,3 4 10,5 6 NaN)'::geometry
+					,'MULTIPOINT(EMPTY,2 1,2 4, 4 5)'::geometry);
+-- https://trac.osgeo.org/postgis/ticket/5635 (split by nan blade)
+SELECT '#5635b', ST_Split('LINESTRING Z (1 2 1,3 4 10,5 6 3)'::geometry
+					,'MULTIPOINT(1 NaN,2 1,2 4, 4 5)'::geometry);
 -- TODO: split line by collapsed line
diff --git a/regress/core/split_expected b/regress/core/split_expected
index b8a5287e9..62ec3cfeb 100644
--- a/regress/core/split_expected
+++ b/regress/core/split_expected
@@ -29,3 +29,5 @@ ERROR:  Splitter line has linear intersection with input
 85|SRID=3;GEOMETRYCOLLECTION(LINESTRING(1 -2,1 -1),LINESTRING(1 -1,1 1,3 1),LINESTRING(3 1,4 1))
 86|SRID=3;GEOMETRYCOLLECTION(LINESTRING(8 0,10 0),LINESTRING(0 0,5 0),LINESTRING(5 0,8 0),LINESTRING(5 0,5 5),LINESTRING(5 -2,5 0),LINESTRING(5 -5,5 -2),LINESTRING(8 20,10 20),LINESTRING(2 20,5 20),LINESTRING(0 20,2 20),LINESTRING(5 20,8 20))
 87|SRID=4326;GEOMETRYCOLLECTION(LINESTRING EMPTY)
+ERROR:  Input Geometry contains invalid coordinates
+ERROR:  Blade Geometry contains invalid coordinates
commit c1a0c55d70e26f19e534fd70b7cc1c8416b16abe
Date:   Fri Dec 1 15:43:18 2023 -0800
    News item for #5604
index 857c5b274..638592a20 100644
--- a/NEWS
+++ b/NEWS
@@ -11,6 +11,7 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.4.1+ is needed.
           in ST_SetPoint (Regina Obe)
+ - #5604, Handle distance between collections with empty elements (Paul Ramsey)
commit f45df01f77442e9e22c431b2d9a8deef7825d799
Date:   Fri Dec 1 15:32:28 2023 -0800
    Correctly handle distances between collections with empty elements, references #5604
diff --git a/liblwgeom/measures.c b/liblwgeom/measures.c
index 3e255f9ec..b22b2cca1 100644
--- a/liblwgeom/measures.c
+++ b/liblwgeom/measures.c
@@ -299,7 +299,7 @@ lw_dist2d_recursive(const LWGEOM *lwg1, const LWGEOM *lwg2, DISTPTS *dl)
 			g1 = (LWGEOM *)lwg1;
 		if (lwgeom_is_empty(g1))
-			return LW_TRUE;
+			continue;
 		if (lw_dist2d_is_collection(g1))
@@ -329,10 +329,9 @@ lw_dist2d_recursive(const LWGEOM *lwg1, const LWGEOM *lwg2, DISTPTS *dl)
 			if (!g2->bbox)
 				lwgeom_add_bbox(g2);
-			/* If one of geometries is empty, return. True here only means continue searching. False would
-			 * have stopped the process*/
+			/* If one of geometries is empty, skip */
 			if (lwgeom_is_empty(g1) || lwgeom_is_empty(g2))
-				return LW_TRUE;
+				continue;
 			if ((dl->mode != DIST_MAX) && (!lw_dist2d_check_overlap(g1, g2)) &&
 			    (g1->type == LINETYPE || g1->type == POLYGONTYPE || g1->type == TRIANGLETYPE) &&
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index a1881fd6c..6623d3fca 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1517,3 +1517,12 @@ FROM (VALUES
     ('MULTIPOLYGON(((-357 477,-392 574,-378 574,-357 477)))'::geometry),
     ('MULTIPOLYGON(((-357 477,-392 574,-378 574,-357 477)))'::geometry))
     AS geoms(geom);
+SELECT '#5604',
+ ST_Distance(a2, a1),
+ ST_AsText(ST_ClosestPoint(a2, a1)),
+ ST_Distance(a1, a2),
+ ST_AsText(ST_ClosestPoint(a1, a2))
+FROM
+ST_GeomFromText('MULTIPOINT((-2 0), EMPTY)') AS a1,
+ST_GeomFromText('MULTIPOINT((1 0),(0 0))') AS a2;
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index 8aa244cbd..f9ae3a346 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -469,3 +469,4 @@ ERROR:  Geometry contains invalid coordinates
 #5378|4269
 #5627|t
+#5604|2|POINT(0 0)|2|POINT(-2 0)
Summary of changes:
 NEWS                          |  2 ++
 liblwgeom/measures.c          |  7 +++----
 postgis/lwgeom_geos.c         | 13 +++++++++++++
 regress/core/split.sql        |  7 +++++++
 regress/core/split_expected   |  2 ++
 regress/core/tickets.sql      |  9 +++++++++
 regress/core/tickets_expected |  1 +
 7 files changed, 37 insertions(+), 4 deletions(-)
hooks/post-receive
