[PostGIS] #5633: postgis_extensions_upgrade() breaks and signalize unbalanced parenteses in regex of regexp_replace function
PostGIS trac at osgeo.org
Mon Dec 4 13:18:34 PST 2023
  Reporter:  hci           |      Owner:  strk
      Type:  enhancement   |     Status:  assigned
  Priority:  low           |  Milestone:  PostGIS PostgreSQL
 Component:  upgrade/soft  |    Version:  3.3.x
Resolution:                |   Keywords:  upgrade extensions regexp_replace
Comment (by robe):
 strk  I think the proper way to write this to not care about what the
 standard_conforming_strings setting is is force escape like so
 So you need 2 \\s instead of 1 slash to escape the (
 pg_catalog.regexp_replace(rec.proc::text,
 E'_deprecated_by_postgis[^(]*\\(.*',
 With that, this query seems to work properly regardless if I have
 standard_conforming_strings on or off
 SELECT pg_catalog.regexp_replace(rec.proc::text,
 E'_deprecated_by_postgis[^(]*\\(.*', '' ), proc
     FROM   (SELECT oid, oid::regprocedure AS proc, proname  FROM pg_proc)
 AS rec
         WHERE proname ~ 'deprecated_by_postgis'
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5633#comment:2>
