[PostGIS] #5496: ST_Clip(raster, geom) include new method to pixel selection: touch
PostGIS trac at osgeo.org
Wed Dec 6 00:29:30 PST 2023
  Reporter:  latot        |      Owner:  robe
      Type:  enhancement  |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS 3.5.0
 Component:  raster       |    Version:  3.4.x
Resolution:               |   Keywords:
Comment (by robe):
 Okay still having issue with the upgrade
 psql:/woodpecker/src/git.osgeo.org/gitea/postgis/postgis/regress/hooks
 /hook-after-upgrade.sql:29: NOTICE:  Dropping function
 st_clip_deprecated_by_postgis_305(raster,integer,geometry,double
 precision,boolean)
 /hook-after-upgrade.sql:29: ERROR:  cannot drop function
 precision,boolean) because other objects depend on it
 DETAIL:  view upgrade_test_raster_view_st_clip depends on function
 precision,boolean)
 HINT:  Use DROP ... CASCADE to drop the dependent objects too.
 CONTEXT:  SQL statement "DROP FUNCTION
 precision,boolean)"
 PL/pgSQL function inline_code_block line 10 at EXECUTE
 make: Leaving directory
 '/woodpecker/src/git.osgeo.org/gitea/postgis/postgis/build/pg12/raster/test/regress'
 FAIL: postgis_raster extension upgrade 3.0.9--3.5.0dev!
 Cleaning up
 precision,boolean)
 precision,boolean)
 precision,boolean)"
 '/woodpecker/src/git.osgeo.org/gitea/postgis/postgis/build/pg15/raster/test/regress'
 FAIL: postgis_raster extension upgrade 3.2.5--3.5.0dev!
 Cleaning up
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5496#comment:6>
