[SCM] PostGIS branch master updated. 3.4.0rc1-833-gca6adcb6d
Fri Dec 8 14:15:44 PST 2023
the project "PostGIS".
       via  ca6adcb6dfee76fa0bb5035f484f3862b0d205c7 (commit)
      from  6a3ec1d928a19f655c49487021d3e6f1775b765c (commit)
revisions in full, below.
commit ca6adcb6dfee76fa0bb5035f484f3862b0d205c7
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Fri Dec 8 14:15:42 2023 -0800
    Update doc to use modern named param syntax
diff --git a/doc/reference_cluster.xml b/doc/reference_cluster.xml
index 0432df691..cb4b4b8e8 100644
--- a/doc/reference_cluster.xml
+++ b/doc/reference_cluster.xml
@@ -93,7 +93,7 @@
 							</mediaobject>
 						  </informalfigure>
   <programlisting><![CDATA[
-SELECT name, ST_ClusterDBSCAN(geom, eps := 50, minpoints := 2) over () AS cid
+SELECT name, ST_ClusterDBSCAN(geom, eps => 50, minpoints => 2) over () AS cid
 FROM boston_polys
 WHERE name > '' AND building > ''
 	AND ST_DWithin(geom,
@@ -140,7 +140,7 @@ WHERE name > '' AND building > ''
         </para>
 		    <programlisting>
 SELECT cid, ST_Collect(geom) AS cluster_geom, array_agg(parcel_id) AS ids_in_cluster FROM (
-    SELECT parcel_id, ST_ClusterDBSCAN(geom, eps := 0.5, minpoints := 5) over () AS cid, geom
+    SELECT parcel_id, ST_ClusterDBSCAN(geom, eps => 0.5, minpoints => 5) over () AS cid, geom
     FROM parcels) sq
 GROUP BY cid;
     </programlisting>
@@ -381,10 +381,10 @@ select
     ST_ClusterKMeans(
         ST_Force4D(
             ST_Transform(ST_Force3D(geom), 4978), -- cluster in 3D XYZ CRS
-            mvalue := population -- set clustering to be weighed by population
+            mvalue => population -- set clustering to be weighed by population
         20,                      -- aim to generate at least 20 clusters
-        max_radius := 3000000    -- but generate more to make each under 3000 km radius
+        max_radius => 3000000    -- but generate more to make each under 3000 km radius
     ) over () as cid
 from
     kontur_population;
@@ -447,7 +447,7 @@ from
         of at least one other geometry in the same cluster.
         Distances are Cartesian distances in the units of the SRID.
         </para>
-        <para>ST_ClusterWithin is equivalent to running <xref linkend="ST_ClusterDBSCAN"/> with <code>minpoints := 0</code>.</para>
+        <para>ST_ClusterWithin is equivalent to running <xref linkend="ST_ClusterDBSCAN"/> with <code>minpoints => 0</code>.</para>
         <para role="availability" conformance="2.2.0">Availability: 2.2.0</para>
         <para>&curve_support;</para>
@@ -511,7 +511,7 @@ GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
         </para>
-        <para>ST_ClusterWithinWin is equivalent to running <xref linkend="ST_ClusterDBSCAN"/> with <code>minpoints := 0</code>.</para>
+        <para>ST_ClusterWithinWin is equivalent to running <xref linkend="ST_ClusterDBSCAN"/> with <code>minpoints => 0</code>.</para>
         <para role="availability" conformance="3.4.0">Availability: 3.4.0</para>
Summary of changes:
 doc/reference_cluster.xml | 12 ++++++------
 1 file changed, 6 insertions(+), 6 deletions(-)
hooks/post-receive
