[SCM] PostGIS branch master updated. 3.4.0rc1-837-g89921fbbe
Sat Dec 9 23:46:29 PST 2023
the project "PostGIS".
       via  89921fbbee9c6127dedab6e3bf08bce48d0cccf5 (commit)
      from  e3f1f803c50f30ed8537115fb0fd496769e00cfd (commit)
revisions in full, below.
commit 89921fbbee9c6127dedab6e3bf08bce48d0cccf5
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Dec 10 02:46:10 2023 -0500
    Fix bg and tabblock20
    Support for new TIGER 2023
    References #5642 for PostGIS 3.5.0
diff --git a/extras/tiger_geocoder/tiger_loader_2023.sql b/extras/tiger_geocoder/tiger_loader_2023.sql
index 6907bb8e5..691176236 100644
--- a/extras/tiger_geocoder/tiger_loader_2023.sql
+++ b/extras/tiger_geocoder/tiger_loader_2023.sql
@@ -296,7 +296,7 @@ VALUES(11, 'tabblock20', 'tabblock20', true, false, true,false, 'c',
 '${psql} -c "SELECT loader_load_staged_data(lower(''${state_abbrev}_${table_name}''), lower(''${state_abbrev}_${lookup_name}'')); "
 ${psql} -c "ALTER TABLE ${data_schema}.${state_abbrev}_${lookup_name} ADD CONSTRAINT chk_statefp CHECK (statefp = ''${state_fips}'');"
 ${psql} -c "CREATE INDEX ${data_schema}_${state_abbrev}_${lookup_name}_the_geom_gist ON ${data_schema}.${state_abbrev}_${lookup_name} USING gist(the_geom);"
-${psql} -c "vacuum analyze ${data_schema}.${state_abbrev}_${lookup_name};"', '{gid}'::text[]);
+${psql} -c "vacuum analyze ${data_schema}.${state_abbrev}_${lookup_name};"', '{gid, geoidfq20, uatype}'::text[]);
 INSERT INTO loader_lookuptables(process_order, lookup_name, table_name, load, level_county, level_state, single_geom_mode, insert_mode, pre_load_process, post_load_process, columns_exclude )
 VALUES(12, 'bg', 'bg', false,false, true,false, 'c',
@@ -304,7 +304,7 @@ VALUES(12, 'bg', 'bg', false,false, true,false, 'c',
 '${psql} -c "ALTER TABLE ${staging_schema}.${state_abbrev}_${table_name} RENAME geoid TO bg_id;  SELECT loader_load_staged_data(lower(''${state_abbrev}_${table_name}''), lower(''${state_abbrev}_${lookup_name}'')); "
-${psql} -c "vacuum analyze ${data_schema}.${state_abbrev}_${lookup_name};"', ARRAY['gid']);
+${psql} -c "vacuum analyze ${data_schema}.${state_abbrev}_${lookup_name};"', ARRAY['gid', 'geoidfq']);
 INSERT INTO loader_lookuptables(process_order, lookup_name, table_name, load, level_county, level_state,  level_nation, single_geom_mode, pre_load_process, post_load_process)
 VALUES(2, 'county_all', 'county', true, false, false, true,
Summary of changes:
 extras/tiger_geocoder/tiger_loader_2023.sql | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
