[SCM] PostGIS branch master updated. 3.4.0rc1-843-g905eafcf8
Tue Dec 12 19:43:40 PST 2023
the project "PostGIS".
       via  905eafcf8a17cdd1d116ad1f53fa2a637d6020ff (commit)
      from  4fa9e106eb839b7bc607ad3597ea62a825e96212 (commit)
revisions in full, below.
commit 905eafcf8a17cdd1d116ad1f53fa2a637d6020ff
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Dec 12 22:43:43 2023 -0500
    Update pot
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index 44f737243..0aa53267d 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -6,7 +6,7 @@ msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2023-11-29 04:00+0000\n"
+"POT-Creation-Date: 2023-12-13 03:42+0000\n"
 "PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
 "Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
 "Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
@@ -7152,7 +7152,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "This will only have data is you marked zcta5 to be loaded"
+msgid "This will only have data if you marked zcta5 to be loaded"
 msgstr ""
 #. Tag: para
@@ -11534,7 +11534,7 @@ msgstr ""
 #, no-c-format
 msgid ""
 "ST_ClusterWithin is equivalent to running <xref linkend=\"ST_ClusterDBSCAN\"/"
-"> with <code>minpoints := 0</code>."
+"> with <code>minpoints => 0</code>."
 msgstr ""
 #. Tag: para
@@ -11566,7 +11566,7 @@ msgstr ""
 #, no-c-format
 msgid ""
 "ST_ClusterWithinWin is equivalent to running <xref "
-"linkend=\"ST_ClusterDBSCAN\"/> with <code>minpoints := 0</code>."
+"linkend=\"ST_ClusterDBSCAN\"/> with <code>minpoints => 0</code>."
 msgstr ""
 #. Tag: para
@@ -22148,43 +22148,55 @@ msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
-"Returns a simplified version of a geometry, using the Douglas-Peucker "
+"Returns a simplified representation of a geometry, using the Douglas-Peucker "
 "algorithm."
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"Returns a \"simplified\" version of the given geometry using the Douglas-"
-"Peucker algorithm. Will actually do something only with (multi)lines and "
-"(multi)polygons but you can safely call it with any kind of geometry. Since "
-"simplification occurs on a object-by-object basis you can also feed a "
-"GeometryCollection to this function."
+"Computes a simplified representation of a geometry using the <link xlink:"
+"href=\"https://en.wikipedia.org/wiki/"
+"Ramer%E2%80%93Douglas%E2%80%93Peucker_algorithm\">Douglas-Peucker algorithm</"
+"link>. The simplification <varname>tolerance</varname> is a distance value, "
+"in the units of the input SRS. Simplification removes vertices which are "
+"within the tolerance distance of the simplified linework. The result may not "
+"be valid even if the input is."
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"The \"preserve collapsed\" flag will retain objects that would otherwise be "
-"too small given the tolerance. For example, a 1m long line simplified with a "
-"10m tolerance. If <varname>preserveCollapsed</varname> argument is specified "
-"as true, the line will not disappear. This flag is useful for rendering "
-"engines, to avoid having large numbers of very small objects disappear from "
-"a map leaving surprising gaps."
+"The function can be called with any kind of geometry (including "
+"GeometryCollections), but only line and polygon elements are simplified. "
+"Endpoints of linear geometry are preserved."
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"Note that returned geometry might lose its simplicity (see <xref "
-"linkend=\"ST_IsSimple\"/>)"
+"The <varname>preserveCollapsed</varname> flag retains small geometries that "
+"would otherwise be removed at the given tolerance. For example, if a 1m long "
+"line is simplified with a 10m tolerance, when <varname>preserveCollapsed</"
+"varname> is true the line will not disappear. This flag is useful for "
+"rendering purposes, to prevent very small features disappearing from a map."
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"Note topology may not be preserved and may result in invalid geometries. Use "
-"(see <xref linkend=\"ST_SimplifyPreserveTopology\"/>) to preserve topology."
+"The returned geometry may lose its simplicity (see <xref "
+"linkend=\"ST_IsSimple\"/>), topology may not be preserved, and polygonal "
+"results may be invalid (see <xref linkend=\"ST_IsValid\"/>). Use <xref "
+"linkend=\"ST_SimplifyPreserveTopology\"/> to preserve topology and ensure "
+"validity."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"This function does not preserve boundaries shared between polygons. Use "
+"<xref linkend=\"ST_CoverageSimplify\"/> if this is required."
 msgstr ""
 #. Tag: para
@@ -22194,27 +22206,52 @@ msgstr ""
 #. Tag: para
 #, no-c-format
-msgid ""
-", <xref linkend=\"ST_SimplifyPreserveTopology\"/>, <xref "
-"linkend=\"ST_SimplifyVW\"/>, Topology <xref linkend=\"TP_ST_Simplify\"/>"
+msgid "Simplifying a set of lines. Lines may intersect after simplification."
 msgstr ""
-#. Tag: refpurpose
+#. Tag: para
 #, no-c-format
-msgid ""
-"Returns a simplified and valid version of a geometry, using the Douglas-"
-"Peucker algorithm."
+msgid "Simplifying a MultiPolygon. Polygonal results may be invalid."
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"Peucker algorithm. Will avoid creating derived geometries (polygons in "
-"particular) that are invalid. Will actually do something only with "
-"(multi)lines and (multi)polygons but you can safely call it with any kind of "
-"geometry. Since simplification occurs on a object-by-object basis you can "
-"also feed a GeometryCollection to this function."
+", <xref linkend=\"ST_SimplifyPreserveTopology\"/>, <xref "
+"linkend=\"ST_SimplifyVW\"/>, <xref linkend=\"ST_CoverageSimplify\"/>, "
+"Topology <xref linkend=\"TP_ST_Simplify\"/>"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"Returns a simplified and valid representation of a geometry, using the "
+"Douglas-Peucker algorithm."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Computes a simplified representation of a geometry using a variant of the "
+"<link xlink:href=\"https://en.wikipedia.org/wiki/"
+"link> which limits simplification to ensure the result has the same topology "
+"as the input. The simplification <varname>tolerance</varname> is a distance "
+"value, in the units of the input SRS. Simplification removes vertices which "
+"are within the tolerance distance of the simplified linework, as long as "
+"topology is preserved. The result will be valid and simple if the input is."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"GeometryCollections), but only line and polygon elements are simplified. For "
+"polygonal inputs, the result will have the same number of rings (shells and "
+"holes), and the rings will not cross. Ring endpoints may be simplified. For "
+"linear inputs, the result will have the same number of lines, and lines will "
+"not intersect if they did not do so in the original geometry. Endpoints of "
+"linear geometry are preserved."
 msgstr ""
 #. Tag: para
@@ -22225,8 +22262,26 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"Same example as Simplify, but we see Preserve Topology prevents "
-"oversimplification. The circle can at most become a square."
+"For the same example as <xref linkend=\"ST_Simplify\"/>, "
+"ST_SimplifyPreserveTopology prevents oversimplification. The circle can at "
+"most become a square."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Simplifying a set of lines, preserving topology of non-intersecting lines."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Simplifying a MultiPolygon, preserving topology of shells and holes."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+", <xref linkend=\"ST_SimplifyVW\"/>, <xref linkend=\"ST_CoverageSimplify\"/>"
 msgstr ""
 #. Tag: refpurpose
@@ -22308,18 +22363,31 @@ msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
-"Returns a simplified version of a geometry, using the Visvalingam-Whyatt "
-"algorithm"
+"Returns a simplified representation of a geometry, using the Visvalingam-"
+"Whyatt algorithm"
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"Returns a \"simplified\" version of the given geometry using the Visvalingam-"
-"Whyatt algorithm. Will actually do something only with (multi)lines and "
+"Returns a simplified representation of a geometry using the <link xlink:"
+"Visvalingam%E2%80%93Whyatt_algorithm\">Visvalingam-Whyatt algorithm</link>. "
+"The simplification <varname>tolerance</varname> is an area value, in the "
+"units of the input SRS. Simplification removes vertices which form "
+"\"corners\" with area less than the tolerance. The result may not be valid "
+"even if the input is."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"validity. <xref linkend=\"ST_CoverageSimplify\"/> also preserves topology "
+"and validity."
 msgstr ""
 #. Tag: para
@@ -22330,15 +22398,26 @@ msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "A LineString is simplified with a minimum area threshold of 30."
+msgid "A LineString is simplified with a minimum-area tolerance of 30."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Simplifying a line."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Simplifying a polygon."
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 ", <xref linkend=\"ST_Simplify\"/>, <xref "
-"linkend=\"ST_SimplifyPreserveTopology\"/>, Topology <xref "
-"linkend=\"TP_ST_Simplify\"/>"
+"linkend=\"ST_SimplifyPreserveTopology\"/>, <xref "
+"linkend=\"ST_CoverageSimplify\"/>, Topology <xref linkend=\"TP_ST_Simplify\"/"
 msgstr ""
 #. Tag: refpurpose
@@ -22376,6 +22455,20 @@ msgid ""
 "this function."
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Note that returned geometry might lose its simplicity (see <xref "
+"linkend=\"ST_IsSimple\"/>)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Note topology may not be preserved and may result in invalid geometries. Use "
+"(see <xref linkend=\"ST_SimplifyPreserveTopology\"/>) to preserve topology."
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid "The output geometry will lose all previous information in the M-values"
@@ -26599,7 +26692,21 @@ msgid ""
 "If <varname>crop</varname> is not specified, true is assumed meaning the "
 "output raster is cropped to the intersection of the <varname>geom</"
 "varname>and <varname>rast</varname> extents. If <varname>crop</varname> is "
-"set to false, the new raster gets the same extent as <varname>rast</varname>."
+"set to false, the new raster gets the same extent as <varname>rast</"
+"varname>. If <varname>touched</varname> is set to true, then all pixels in "
+"the <varname>rast</varname> that intersect the geometry are selected."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The default behavior is touched=false, which will only select pixels where "
+"the center of the pixel is covered by the geometry."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Enhanced: 3.5.0 - touched argument added."
 msgstr ""
 #. Tag: para
@@ -26611,13 +26718,18 @@ msgstr ""
 #, no-c-format
 msgid ""
 "Examples here use Massachusetts aerial data available on MassGIS site <link "
-"xlink:href=\"http://www.mass.gov/mgis/colororthos2008.htm\">MassGIS Aerial "
-"Orthos</link>. Coordinates are in Massachusetts State Plane Meters."
+"xlink:href=\"https://www.mass.gov/info-details/massgis-data-20082009-aerial-"
+"imagery\">MassGIS Aerial Orthos</link>."
 msgstr ""
 #. Tag: title
 #, no-c-format
-msgid "Examples: 1 band clipping"
+msgid "Examples: Comparing selecting all touched vs. not all touched"
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Examples: 1 band clipping (not touched)"
 msgstr ""
 #. Tag: para
@@ -26649,8 +26761,8 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-", <xref linkend=\"RT_ST_MapAlgebra\"/>, <xref linkend=\"RT_ST_Intersection\"/"
+", <xref linkend=\"RT_ST_Count\"/>, <xref linkend=\"RT_ST_MapAlgebra\"/>, "
+"<xref linkend=\"RT_ST_Intersection\"/>"
 msgstr ""
 #. Tag: refpurpose
Summary of changes:
 doc/po/templates/postgis-manual.pot | 206 ++++++++++++++++++++++++++++--------
 1 file changed, 159 insertions(+), 47 deletions(-)
hooks/post-receive
