[SCM] PostGIS branch master updated. 3.4.0rc1-848-g09a3d66e7
Tue Dec 12 22:19:29 PST 2023
the project "PostGIS".
       via  09a3d66e7b3d6fb9d6dce20807d5641e4932e739 (commit)
      from  246665a4bd5da35209b023e2b52523e2a791152a (commit)
revisions in full, below.
commit 09a3d66e7b3d6fb9d6dce20807d5641e4932e739
Author: Regina Obe <lr at pcorp.us>
Date:   Wed Dec 13 01:19:24 2023 -0500
    Fix section abstract.  References #5643 for PostGIS 3.5.0
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index 7ab8bea3c..072c69ee2 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -31200,6 +31200,13 @@ msgstr ""
 msgid "SFCGAL Management Functions"
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"This section lists functions for determining version of SFCGAL and library "
+"dependencies you are running."
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid "<refpurpose>Returns the version of SFCGAL in use</refpurpose>"
diff --git a/doc/reference_sfcgal.xml b/doc/reference_sfcgal.xml
index cbc40ef95..f23942450 100644
--- a/doc/reference_sfcgal.xml
+++ b/doc/reference_sfcgal.xml
@@ -12,6 +12,12 @@
 	<section xml:id="sfcgal_management">
 		<title>SFCGAL Management Functions</title>
+		<info>
+				<abstract>
+						<para>This section lists functions for determining version of SFCGAL and library dependencies you are running.</para>
+				</abstract>
+    </info>
 		<refentry xml:id="postgis_sfcgal_version">
 			<refnamediv>
 			<refname>postgis_sfcgal_version</refname>
@@ -79,9 +85,11 @@
 	<section xml:id="sfcgal_accessors">
 		<title>SFCGAL Accessors and Setters</title>
-		<abstract>
-		<para>These functions access or set properties of geometries. Geometries primarily supported by these functions are TINS and Polyhedral Surfaces.</para>
-		</abstract>
+		<info>
+				<abstract>
+						<para>These functions access or set properties of geometries. Geometries primarily supported by these functions are TINS and Polyhedral Surfaces.</para>
+				</abstract>
+    </info>
 		<refentry xml:id="ST_3DArea">
 			<refnamediv>
Summary of changes:
 doc/po/templates/postgis-manual.pot |  7 +++++++
 doc/reference_sfcgal.xml            | 14 +++++++++++---
 2 files changed, 18 insertions(+), 3 deletions(-)
hooks/post-receive
