[SCM] PostGIS branch master updated. 3.4.0rc1-853-ge94b8f2ab
Thu Dec 14 06:25:54 PST 2023
the project "PostGIS".
       via  e94b8f2ab1f2560f9d2bb94401d5b5bb1c840e72 (commit)
       via  86a56deffabe9ecc6088e78fb5350f76118fe9cc (commit)
      from  9f2c47c9364a35caf3737e0cd18d3e3ccbaba67f (commit)
revisions in full, below.
commit e94b8f2ab1f2560f9d2bb94401d5b5bb1c840e72
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Dec 14 14:41:45 2023 +0100
    Re-add raster upgrade test view dropped in 4fa9e106e
    References #5488
    References #5496
diff --git a/raster/test/regress/hooks/hook-after-upgrade-raster.sql b/raster/test/regress/hooks/hook-after-upgrade-raster.sql
index 03bf5b9cd..0f3771f5c 100644
--- a/raster/test/regress/hooks/hook-after-upgrade-raster.sql
+++ b/raster/test/regress/hooks/hook-after-upgrade-raster.sql
@@ -1,4 +1,5 @@
 DROP VIEW upgrade_test_raster_view_st_value;
+DROP VIEW upgrade_test_raster_view_st_clip;
 DROP VIEW upgrade_test_raster_view_st_intersects;
 DROP TABLE upgrade_test_raster;
@@ -7,5 +8,5 @@ DROP TABLE upgrade_test_raster_with_regular_blocking;
 DROP VIEW upgrade_test_raster_view_st_slope;
 DROP VIEW upgrade_test_raster_view_st_aspect;
--- Drop functions deprecated on upgrade
-DROP FUNCTION IF EXISTS st_value_deprecated_by_postgis_201(raster,geometry,boolean);
+-- Drop deprecated functions
+\i :regdir/hooks/drop-deprecated-functions.sql
diff --git a/raster/test/regress/hooks/hook-before-upgrade-raster.sql b/raster/test/regress/hooks/hook-before-upgrade-raster.sql
index 7abd27a7c..d2aa997f9 100644
--- a/raster/test/regress/hooks/hook-before-upgrade-raster.sql
+++ b/raster/test/regress/hooks/hook-before-upgrade-raster.sql
@@ -38,6 +38,19 @@ SELECT
 	ST_Value(r, ST_MakePoint(0, 0))
 FROM upgrade_test_raster;
+--- See https://trac.osgeo.org/postgis/ticket/5488
+CREATE VIEW upgrade_test_raster_view_st_clip AS
+SELECT
+       -- signature dropped in PostGIS-2.1.0
+       --st_clip(NULL::raster, NULL::int, NULL::geometry, NULL::float8[], NULL::boolean),
+       -- sig1 new in PostGIS-2.1.0
+       --st_clip(NULL::raster, NULL::int[], NULL::geometry, NULL::float8[], NULL::boolean),
+       st_clip(NULL::raster, NULL::int, NULL::geometry, NULL::float8, NULL::boolean) sig2,
+       st_clip(NULL::raster, NULL::int, NULL::geometry, NULL::boolean) sig3,
+       st_clip(NULL::raster, NULL::geometry, NULL::float8[], NULL::boolean) sig4,
+       st_clip(NULL::raster, NULL::geometry, NULL::float8, NULL::boolean) sig5,
+       st_clip(NULL::raster, NULL::geometry, NULL::boolean) sig6;
 -- See https://trac.osgeo.org/postgis/ticket/5489
 CREATE VIEW upgrade_test_raster_view_st_intersects AS
 SELECT
diff --git a/regress/hooks/drop-deprecated-functions.sql b/regress/hooks/drop-deprecated-functions.sql
new file mode 100644
index 000000000..770aafab5
--- /dev/null
+++ b/regress/hooks/drop-deprecated-functions.sql
@@ -0,0 +1,22 @@
+-- Drop functions deprecated on upgrade, if possible (could be possible later)
+DO LANGUAGE 'plpgsql' $DROPALL$
+DECLARE
+	rec pg_catalog.pg_proc;
+BEGIN
+	FOR rec IN
+		SELECT * FROM pg_catalog.pg_proc
+		WHERE proname ~ '_deprecated_by_postgis'
+	LOOP
+		RAISE NOTICE 'Dropping function %', rec.oid::regprocedure;
+		BEGIN
+			EXECUTE pg_catalog.format('DROP FUNCTION %s', rec.oid::regprocedure);
+		EXCEPTION
+		WHEN dependent_objects_still_exist THEN
+			RAISE NOTICE 'Could not drop function % as dependent objects still exist', rec.oid::regprocedure;
+		WHEN OTHERS THEN
+			RAISE EXCEPTION 'Got % (%)', SQLERRM, SQLSTATE;
+		END;
+	END LOOP;
+END;
+$DROPALL$;
diff --git a/regress/hooks/hook-after-upgrade.sql b/regress/hooks/hook-after-upgrade.sql
index c0516610d..64ce9d770 100644
--- a/regress/hooks/hook-after-upgrade.sql
+++ b/regress/hooks/hook-after-upgrade.sql
@@ -13,17 +13,5 @@ DROP TABLE IF EXISTS upgrade_test;
 -- Drop any upgrade test data
 DROP SCHEMA IF EXISTS postgis_upgrade_test_data CASCADE;
-DO LANGUAGE 'plpgsql' $DROPALL$
-DECLARE
-	rec pg_catalog.pg_proc;
-BEGIN
-	FOR rec IN
-		SELECT * FROM pg_catalog.pg_proc
-		WHERE proname ~ '_deprecated_by_postgis'
-	LOOP
-		RAISE NOTICE 'Dropping function %', rec.oid::regprocedure;
-		EXECUTE pg_catalog.format('DROP FUNCTION %s', rec.oid::regprocedure);
-	END LOOP;
-END;
-$DROPALL$;
commit 86a56deffabe9ecc6088e78fb5350f76118fe9cc
Date:   Thu Dec 14 15:18:33 2023 +0100
    Make :regdir available to hooks
diff --git a/regress/run_test.pl b/regress/run_test.pl
index bc4daf5e7..7c297ba6d 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -1581,6 +1581,7 @@ sub load_sql_file
 		my $cmd = "psql $psql_opts -c 'CREATE SCHEMA IF NOT EXISTS $OPT_SCHEMA' ";
 		$cmd .= "-c 'SET search_path TO $OPT_SCHEMA,topology'";
 		$cmd .= " -v \"opt_dumprestore=${OPT_DUMPRESTORE}\"";
+		$cmd .= " -v \"regdir=$REGDIR\"";
 		$cmd .= " -Xf $file $DB >> $REGRESS_LOG 2>&1";
 		#print "  $file\n" if $VERBOSE;
 		my $rv = system($cmd);
Summary of changes:
 .../regress/hooks/hook-after-upgrade-raster.sql    |  5 +++--
 .../regress/hooks/hook-before-upgrade-raster.sql   | 13 +++++++++++++
 regress/hooks/drop-deprecated-functions.sql        | 22 ++++++++++++++++++++++
 regress/hooks/hook-after-upgrade.sql               | 16 ++--------------
 regress/run_test.pl                                |  1 +
 5 files changed, 41 insertions(+), 16 deletions(-)
 create mode 100644 regress/hooks/drop-deprecated-functions.sql
hooks/post-receive
