[PostGIS] #5648: postgis_raster upgrade fails on PG16
PostGIS trac at osgeo.org
Tue Dec 19 08:17:34 PST 2023
  Reporter:  rdunklau  |      Owner:  robe
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.4.2
 Component:  raster    |    Version:  3.4.x
Resolution:            |   Keywords:
Description changed by rdunklau:
Old description:
> postgis_raster upgrade fails on PG16 with the error message:
> ERROR: attempt to redefine parameter "postgis.gdal_datapath"
> This comes from the implementation of postgis_guc_find_option for PG16,
> which passes a random address instead of the GUC name.
> Here is a real simple patch fixing that:
> diff --git a/libpgcommon/lwgeom_pg.c b/libpgcommon/lwgeom_pg.c
> index 6af4bea39..f7f848adc 100644
> --- a/libpgcommon/lwgeom_pg.c
> +++ b/libpgcommon/lwgeom_pg.c
> @@ -521,7 +521,7 @@ postgis_guc_find_option(const char *name)
>          * the name field is first in config_generic.
>  #if POSTGIS_PGSQL_VERSION >= 160
> -       res = (struct config_generic **) find_option((void *) &key,
> false, true, ERROR);
> +       res = (struct config_generic **) find_option((void *) name,
>  #else
>         res = (struct config_generic **) bsearch((void *) &key,
>                  (void *) get_guc_variables(),
> 2.43.0
New description:
 -       res = (struct config_generic **) find_option((void *) &key, false,
 true, ERROR);
 +       res = (struct config_generic **) find_option((void *) name, false,
 true, ERROR);
  #else
 2.43.0
 One should probably remove the cast to (void *) while at it
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5648#comment:2>
