[SCM] PostGIS branch master updated. 3.4.0rc1-859-ga0d447769
Mon Dec 25 19:45:25 PST 2023
the project "PostGIS".
       via  a0d44776928884d487f226d3c1b3610253c47f90 (commit)
      from  ac27d4a94a85f05e959e707685c43a87ed33a2f2 (commit)
revisions in full, below.
commit a0d44776928884d487f226d3c1b3610253c47f90
Author: Zuochenwei <zuochenwei5 at gmail.com>
Date:   Tue Dec 26 01:49:56 2023 +0000
    Translated PostGIS Manual using Weblate (Chinese (Simplified))
    Currently translated at 100.0% (5669 of 5669 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/zh_Hans/
diff --git a/doc/po/zh_Hans/postgis-manual.po b/doc/po/zh_Hans/postgis-manual.po
index 22da056f8..76f445d4a 100644
--- a/doc/po/zh_Hans/postgis-manual.po
+++ b/doc/po/zh_Hans/postgis-manual.po
@@ -1,12 +1,13 @@
 # Chinese translations for postgis package.
 # Automatically generated, 2023.
+# Zuochenwei <zuochenwei5 at gmail.com>, 2023.
 msgid ""
 msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-12-13 03:42+0000\n"
-"PO-Revision-Date: 2023-12-14 08:23+0000\n"
+"PO-Revision-Date: 2023-12-26 03:45+0000\n"
 "Last-Translator: Zuochenwei <zuochenwei5 at gmail.com>\n"
 "Language-Team: Chinese (Simplified) <https://weblate.osgeo.org/projects/"
 "postgis/postgis-manual/zh_Hans/>\n"
@@ -15,7 +16,7 @@ msgstr ""
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "Plural-Forms: nplurals=1; plural=0;\n"
-"X-Generator: Weblate 5.0\n"
+"X-Generator: Weblate 5.3\n"
 #. Tag: chapter
 #, no-c-format
@@ -36424,9 +36425,10 @@ msgid ""
 "equivalently, no points of A lie in the exterior of B), and the interiors of "
 "A and B have at least one point in common."
 msgstr ""
-"如果几何图形 A 位于几何图形 B 内,则返回 TRUE。当且仅当 A 的所有点都位于 B 内"
-"部(即位于 B 的内部或边界)时,A 位于 B 内(或者等效地,A 的任何点均位于 B 的"
-"外部), A 和 B 的内部结构至少有一个共同点。"
+"如果几何对象 A 完全包含在几何对象 B 内部(即 A 的所有点都在 B "
+"的内部或边界上),并且 A 和 B 的内部至少有一个公共点,则返回 TRUE。等价地,A "
+"在 B 中,当且仅当 A 的所有点都位于 B 的内部(包括边界),且 A 和 B "
+"的内部至少有一个点重叠。"
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/zh_Hans/postgis-manual.po | 12 +++++++-----
 1 file changed, 7 insertions(+), 5 deletions(-)
hooks/post-receive
