[SCM] PostGIS branch master updated. 3.4.0rc1-867-g03e8bc97e
Wed Dec 27 00:38:06 PST 2023
the project "PostGIS".
       via  03e8bc97e2015d466aee4b15819c9f65e781e68e (commit)
       via  6f0f6ef6d46b42c88d8969f4d1b6982b226fa677 (commit)
       via  fb0a6302ede53e19bf696eae183f8010eeab8b57 (commit)
       via  300a616c3fc616605e0bb0d55cb5abdd81e88daf (commit)
      from  18e7f66cfc6f51179bed0866c600891679684d6a (commit)
revisions in full, below.
commit 03e8bc97e2015d466aee4b15819c9f65e781e68e
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Dec 26 17:46:14 2023 +0100
    Use escaped string to not depend on standard_conforming_strings
    References #5633
diff --git a/postgis/common_after_upgrade.sql b/postgis/common_after_upgrade.sql
index 09f9ea2a4..5e9ec2b0f 100644
--- a/postgis/common_after_upgrade.sql
+++ b/postgis/common_after_upgrade.sql
@@ -51,7 +51,7 @@ BEGIN
         new_name := pg_catalog.regexp_replace(
             rec.proc::text,
-            '_deprecated_by_postgis[^(]*\(.*',
+            E'_deprecated_by_postgis[^(]*\\(.*',
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 69cbb00d5..08e13a05d 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -29,7 +29,7 @@ DO $$
 DECLARE
 	pgver text;
 BEGIN
-	SELECT pg_catalog.substring(pg_catalog.version(), 'PostgreSQL ([0-9\.]+)') INTO pgver;
+	SELECT pg_catalog.substring(pg_catalog.version(), E'PostgreSQL ([0-9\\.]+)') INTO pgver;
 	IF POSTGIS_PGSQL_VERSION::text != ( SELECT CASE
 		WHEN pg_catalog.split_part(s,'.',1)::integer > 9
@@ -37,7 +37,7 @@ BEGIN
 		ELSE
 			pg_catalog.split_part(s,'.', 1) || pg_catalog.split_part(s,'.', 2)
 		END
-		FROM pg_catalog.substring(pg_catalog.version(), 'PostgreSQL ([0-9\.]+)') AS s )
+		FROM pg_catalog.substring(pg_catalog.version(), E'PostgreSQL ([0-9\\.]+)') AS s )
 	THEN
 		RAISE EXCEPTION 'PostGIS built for PostgreSQL % cannot be loaded in PostgreSQL %',
 			POSTGIS_PGSQL_HR_VERSION, pgver;
@@ -3124,7 +3124,7 @@ CREATE OR REPLACE FUNCTION _postgis_pgsql_version() RETURNS text
 AS $$
 	SELECT CASE WHEN pg_catalog.split_part(s,'.',1)::integer > 9 THEN pg_catalog.split_part(s,'.',1) || '0'
 	ELSE pg_catalog.split_part(s,'.', 1) || pg_catalog.split_part(s,'.', 2) END AS v
-	FROM pg_catalog.substring(version(), 'PostgreSQL ([0-9\.]+)') AS s;
+	FROM pg_catalog.substring(version(), E'PostgreSQL ([0-9\\.]+)') AS s;
 $$ LANGUAGE 'sql' STABLE;
 -- Availability: 2.5.0
diff --git a/regress/hooks/use-all-functions.sql b/regress/hooks/use-all-functions.sql
index 62d0405ea..74e5f2517 100644
--- a/regress/hooks/use-all-functions.sql
+++ b/regress/hooks/use-all-functions.sql
@@ -13,8 +13,8 @@ BEGIN
 							oid::regprocedure::text,
 							'double precision', 'float8'
-						'(NULL::\1'
+						E'\\(([^)])',
+						E'(NULL::\\1'
 					',NULL::',
commit 6f0f6ef6d46b42c88d8969f4d1b6982b226fa677
Date:   Tue Dec 5 10:38:05 2023 +0100
    [woodie] add upgrade tests with standard_conforming_strings off
    References #5633
diff --git a/.woodpecker/regress.yml b/.woodpecker/regress.yml
index cd7a228aa..642b5bb7a 100644
--- a/.woodpecker/regress.yml
+++ b/.woodpecker/regress.yml
@@ -39,6 +39,10 @@ variables:
     - wait # for tee process to flush its buffers
     - echo "-- Summary of upgrade tests --"
     - egrep '(PASS|FAIL|SKIP|INFO|ERROR)' check.log
+    - echo "-- Upgrade tests with standard_conforming_strings off --"
+    - RUNTESTFLAGS="$${RUNTESTFLAGS} --after-create-db-script $${SRCDIR}/regress/hooks/standard-conforming-strings-off.sql"
+      MAKE_ARGS='TESTS=$${SRCDIR}/regress/core/regress'
+      $${SRCDIR}/utils/check_all_upgrades.sh -s :auto!
 clone:
   clone:
commit fb0a6302ede53e19bf696eae183f8010eeab8b57
Date:   Tue Dec 5 10:37:41 2023 +0100
    Add hook to set standard_conforming_string off in test database
    References #5633
diff --git a/regress/hooks/standard-conforming-strings-off.sql b/regress/hooks/standard-conforming-strings-off.sql
new file mode 100644
index 000000000..6b15d2100
--- /dev/null
+++ b/regress/hooks/standard-conforming-strings-off.sql
@@ -0,0 +1,12 @@
+-- See https://trac.osgeo.org/postgis/ticket/5633
+DO $BODY$
+BEGIN
+	EXECUTE format(
+			ALTER DATABASE %I
+			SET standard_conforming_strings to off
+		current_database()
+END;
+$BODY$ LANGUAGE 'plpgsql';
commit 300a616c3fc616605e0bb0d55cb5abdd81e88daf
Date:   Wed Dec 27 08:50:18 2023 +0100
    Avoid double inclusion of postgis_revision.h
    The header is already pulled in by postgis_config.h which is
    included by liblwgeom_internal.h
diff --git a/liblwgeom/lwgeom_api.c b/liblwgeom/lwgeom_api.c
index 43e5d374b..e966251d5 100644
--- a/liblwgeom/lwgeom_api.c
+++ b/liblwgeom/lwgeom_api.c
@@ -30,7 +30,6 @@
 #include <stdio.h>
 #include <assert.h>
-#include "../postgis_revision.h"
 #define xstr(s) str(s)
 #define str(s) #s
Summary of changes:
 .woodpecker/regress.yml                           |  4 ++++
 liblwgeom/lwgeom_api.c                            |  1 -
 postgis/common_after_upgrade.sql                  |  2 +-
 postgis/postgis.sql.in                            |  6 +++---
 regress/hooks/standard-conforming-strings-off.sql | 12 ++++++++++++
 regress/hooks/use-all-functions.sql               |  4 ++--
 6 files changed, 22 insertions(+), 7 deletions(-)
 create mode 100644 regress/hooks/standard-conforming-strings-off.sql
hooks/post-receive
